VertX Last Call pack CCW laptop backpack+ 11"x18" level IIIA+ soft armor panel insert - STILL AVAILABLE
L.A. Saiga
Feedback: +367 / =0 / -0
VertX Last Call pack CCW laptop backpack+ 11"x18" level IIIA+ soft armor panel insert, SOLD
100% Brand new in packaging never used in any way. Never been out of packaging except now for pictures.
I bought this for my train ride to work but i now work from home - so i'm passing this on.
The 11x18 soft armor panel is undetectable and there's still a TON of space for your laptop and gear.
Active shooter? or maybe stuck in chaos? I would put the backpack on in the front and you have 18" of coverage for your torso.
backpack:
VertX 'Last Call Pack' (all black) model: VTX5080 IBK
armor panel insert:
Botach Battlesteel BME-1118. This is level 3A+ soft armor is 11" X 18" UHMWPE (ultra high molecular weight polyethylene) and protects against all handgun and shotgun rounds.
Battle Steel part # is: BME-1118 from Botach.com. SKU: BSFBA10153A+VTX5016 weight of soft armor panel is 2.5 pounds.
Questions? Comments? Please send me a Private Message
No Trades please
Thanks for looking
from the makers webpage:
When space and weight are important, this grab-and-go Last Call pack is perfect for keeping your essential tools close at hand. The gear in your CCW compartment is just a tug away with the Rapid Access Pull tab and the main compartment opens like a clamshell to let you load, find and remove items quickly and easily. The front flap quickly stows behind the MOLLE panel it covers and additional storage space is available in external pockets.
Features:
  • Weapon-compatible concealed carry platform with loop lining and a Rapid Access Pull tab
  • Concealed carry platform accepts ballistic panels
  • Convertible front panel stows behind loop-faced MOLLE webbing to provide ready access to items mounted there and to rapidly change the bag’s appearance
  • G-hook straps enable front panel to convert to a sling for larger items
  • Main compartment has a laptop sleeve, two gear slots, one abrasion-resistant zippered mesh pocket and loop panel for Tactigami™ and other hook and loop-compatible accessories
  • Front flap closes at multiple heights to secure multiple load sizes
  • Stretch side pockets for water bottles or similarly-sized necessities
  • 3-D molded foam back panel enhances airflow and comfort and has a pass-through for rolling luggage handles
  • Multiple strategically-located and Tactigami™-compatible loop panels
  • Adjustable shoulder and sternum straps
  • Hydration bladder compatible with dual hose pass-through ports
  • Light-colored interior improves internal visibility
  • Fits up to 15” laptop
Construction:
  • Bonded nylon thread throughout with critical seams and attachment points bartacked for extra durability
  • VELCRO® Brand loop for top-of-the-line retention of Tactigami™ and other hook and loop-compatible accessories (accessories sold separately)
  • YKK® self-repairing nylon coil zippers throughout
  • Quiet positive-grip zipper pull tabs
  • 3-D molded foam back panel and laptop insert
  • Abrasion-resistant mesh used on internal pocket
Specifications:
  • Outside Dimensions: 18”H x 14”W x 6”D
  • CCW Compartment Dimensions: 17.25”H x 11”W x 1”D (18.5”L diagonal)
  • Main Compartment: 18”H x 14”W x 5” (20”L diagonal)
  • 65 lb
  • 20 L
    Thank you
