Very curious about CPM 154!
One of my favorite things about knives is learning about and using different steels, so when I read a thread here about the new Kershaw Bump with a CPM 154 blade, I was very interested and even more because and I've always liked 154 CM.
So, is there a place on the web to read more about it? Are there any other knives that use this steel? What do we know about it so far? How does it compare to other steels?
Thanks for any info! :)
We had a discussion about it a while ago. Here's a link to an explanation from conan, a Crucible employee:
Crucible specifically developed CPMS30V to be a tough, stainless knife blade steel. Our research people worked on this for approximately 18 months. Feedback from most custom makers and production companies would suggest we accomplished our goal. However, CPMS30V does have one or two shortcomings. It is more difficult to finish than ATS34 and 154CM and it does cost more.
Because we do listen to custom knife makers, we are now offering CPM154. CPM154 is our attempt at offering a premium stainless knife blade steel that is more user friendly - easier to finish - easier to grind and polish. Because we use the CPM process to make CPM154 it should also outperform conventional 154CM. Before we will promote CPM154 as a success(achieving our intended goal) - we wait to hear from the custom makers who are using it. If they have good things to say and endorse the grade we will forge ahead. If feedback is negative we will go back to the drawing board and make the necessary adjustments to try and meet the custom makers' needs and suggestions.
Also, based on our experience with CPMS30V, it is still a better grade than conventional 154CM and better than CPM154 but, as mentioned above, is difficult to finish.
ATS34 is also a great stainless knife blade steel and will always be a main-stay in the stainless knife blade steel family.
On the topic of heat treatment, it doesn't matter what steel we are talking about, if it is not heat treated correctly it will not attain its full potential.
Lastly, 154CM and ATS34 are basically the same steel. They are both very good stainless knife blade steels.
At the Oregon show last April Crucible did a seminar on steels. The new CPM154 was a hot topic. Crucible said one of their goals was to have a steel that could be polished to the "pooled mercury" look. Sal Glesser from Spyderco said they were getting 1-2 points higher in hardness over the standard 154CM in their testing. I personally like 154CM and I think the improved CPM154 has the potential to be great!
I got the new Kershaw Bump about a month ago. It has a blade made from CPM154. I also have the frame lock Bump with a blade from S30V. I've been doing some testing but I haven't come to any conclusions yet. If you want to see the new stud lock bump click here. You will have to scroll down the page.
Thanks for the information! It sounds like a steel I really want to try.
BTW, the "stud lock bump click here" link insn't working for me. I'm not sure if the link is messed up or it's just my computer.
