Hello all:
I am new to the forum, but have lurked for a long time.
I'm in the process of stepping up from files to -> cheapo 1 x 42 to -> to 2 x 72 grinder.
My VFD is a Nema 4x JNEV-202-H1FN4S Teco 2HP VFD.
This will be paired up with a Siemens 3 pole 3600 rpm 1.5 HP motor.
I'm using 12/2 wire with a double pole 20 amp breaker to a Nema 6-20 receptacle (240V) for the VFD Input power source.
I have a 10' Nema 6-20 12 ga power cord that I'm going to cut the female end off.
I know I could get away with 15 amp, but nema 6-20 stuff seems more available than 6-15.
From what I've read, do not need neutral, just (2) 120 V hot into VFD (hence Nema 6-20 selection)
Based on the note in the manual (L2 will be non-function for single phase units) and the jumpers from the L1 & L3 points coming from the switch....I'm thinking my hot wires should go to L1 & L3.
But the diagram is not 100% clear to me in the instruction manual.....
Anyone know for certain if the 2nd hot line should be in the L2 or L3 terminal?
Thanks ahead for any help. Pictures below.
Tony
https://flic.kr/p/Vrczw8
Tony
