There was no mention of such extreme use in my last post, I gave two examples of cutting cardboard and how the requirements of the user will change which steel is optimal. Getting specific look at the following link and specifically compare the advantage BG-42 has over 420HC which both have the Edge 2000 process. Note how the advantage of BG-42 is minimal if you keep your blades cutting very sharp :
http://www.bladeforums.com/forums/showthread.php?t=421313
Then consider all the disadvantges of BG-42, cost, harder to grind, lower corrosion resistance, toughness, etc. . Further still look at the 440C vs 420HC data provided there and then ask your dealer which is a better steel. Now show them those CATRA results and ask them them if they have any experience which contradicts it or are they just repeating what they heard someone else say in order to sell the products which feature those steels.
If you don't like CATRA results because machines are too abstract, then read Landes work who says the same thing, as does Verhoeven and so does Johnston - in principle. Forget about the specific steels they are talking about and look at the characteristics of those steels and how they influence behavior. This is why people who like low alloy carbon steels like 52100 will praise the Sandvik steels because they have very similar properties.
As for what makers use - this will always be influenced strongly by public perception and that should be obvious. I can guarantee, without any doubt that you will see more and more makers offering the fine carbide steels as it becomes more publically known that high carbide steels have problems in regards to optimal performance
as a cutting steel for obtaining and keeping a high sharpness, in addition to issue with toughness.
Right now the main focus is pretty much all about maximal carbide fraction hence people will say for example S60V is a much better steel than ATS-34. However the edge stability of ATS-34 is actually slightly higher and thus it will get sharper and hold that high sharpness longer, S60V just stays blunter for longer. ATS-34 isn't a great example of that type of steel of course as it also has a high carbide fraction of very large carbides but it is better in that regard than S60V.
-Cliff
