- Jan 22, 2007
Thanks Rainddog, that was very kind words!
Here's a new pic of the NL1 together with some of the others, in a glass displaycase.
Regards
Mikael
My oh my... some beautiful pieces there!
Regards
Mikael
He was asking about VG-10 in general with an eye on a fallk... so pointing out that vg-10 laminate and VG-10 knives are different is helpful when talking about toughness.. because in the end you really are talking about two entirely different blade materials and only the edge holding being the same across them.
Eric, CEO of Fällkniven AB, told me of his solid VG-10 A1.
He wanted to try the laminated A1 when it was new,but had to break the old solid one before he started on the new A1.
He deliberately used it as hard as he could, trying to break it.
The last I heard of it, he still had the solid one!
Regards
Mikael
This story, of Eric trying to break his A1, makes me sad. So, because I am a generous soul, I want to help him out, by giving that worn out old A1 a home. That way, he can move on to the laminated version, and stop wasting his time on that stubborn old solid version that won't break!
Raindog, for what it's worth, my experiences with Fallkniven's VG10 laminate (in the S1 model) mirror those of Mikael's. I've taken nearly every opportunity I've found to recommend their knives. I haven't had any of the chipping problems that others have spoken of. My use has been a lot of woodwork, with just a bit of it being light chopping. I've only ever stropped, or in the worst case, used 1500 grit wet/dry sandpaper to bring the edge back after use, and it seems to improve more with every sharpening. I know the S1 isn't quite the size of the A1 you're looking at, but I figured it's close enough to the A1 to give you a decent representation of what you can expect.
Ive read a review of vg-10 F1 being used to try to chisel though a steel bar and it suffering eraser sized chips in the blade, while 1095 managed it.
This is in line with when I have used 1095 at 58rc to cut high tensile fencing wire.
Here
http://www.cliffstamp.com/knives/reviews/metal_cutting.html#fallkniven
Thanks for the input. Seems like there are near-unanimous recommendations for the VG10 that FK uses. Sounds good to me. My only decision now is whether to go for the A1, or splurge on something like the Odin. I like me some stacked leather handles!
Got a reply from Fallkniven, they state any chipping problems were fixed long ago.
Guessing why they went laminate... Also means I was wrong about the mc1z.
The last paragraph of that link is very important.
His actual review of the Solid VG10 A1 was a bit more telling.
It is too bad that Noss retired and let his videos and photos disappear...
http://www.bladeforums.com/forums/s...allkniven-A1-Destruction-Test-Video-Completed
He performed a "destruction test" on a laminated A1 that was total madness
The knife came quite sharp. Smashing it into concrete, even at factory thickness, resulted in some chipping (bad) followed by denting (minor). Also a bit of the tip snapped off relatively easily when stabbed/bent into sheet metal. Both of these may be due to "burnt" edges, which is something to take note of even if you don't intend to use the knife thus(I hope not) It would have been nice to see how a corrected edge would have performed, but such was not the nature of Noss' tests.
What was truly impressive was how strong the laminated blade is! Noss bounced 225lbs on the handle with the blade vised ~2.5" from the hilt until it fractured (again, no surprise, especially at this thickness) ... but it didn't snap! Due to the lamination, lateral stress encounters resistance from 3 separate layers of steel - even if one fails, the others keep the knife intact. After this, the blade was hammered with a 3-lb steel mallet through 1/8" x 2" mild steel without total failure (very rare in Noss' 'tests').
Should you then feel comfortable using the A1 as a concrete chisel or diving board or pounding through steel plate? I really hope not... but know that it CAN take it, so lesser tasks shouldn't be a problem as far as damage is concerned :thumbup:
That isn't to say that there are not "better" knives out there, be it higher cutting performance or aesthetics, etc. But is the A1 prone to breakage or chipping during simple wood-processing? I wish the videos were still around for you to see just how NOT prone the A1 is. That's my $0.02.
