Cobalt
Platinum Member
- Dec 23, 1998
I always hear about vibration when hammering or chopping with certain tools. What is this phenomena. VIBRATION. There are two types; one is free vibration and the other is forced vibration. Forced is the type we are talking about here. It is induced by external forces. In order to dampen vibrations the natural frequency of the supporting material must be smaller or different than the disturbing or impact frequency(laymans terms of course). In mechanical devices this is done by use of springs and for example rubber padded motor mounts in cars. These things serve to reduce the vibrations transmitted to the user. How does this transfer to knives. Well let's take any knife. All steels operate at the same basic frequencies, which is a combination of density, shape,mass and size. For all intents and purposes all knives will transmit vibrations relatively equally regardless of physical differences because the differences are so slight. So how do you reduce the impact vibration. Well by means of handle material. For all intents and purposes, the more fibrous, sponge(less density) the material the more absorbent it will be. Layers of dissimilar materials also reduce vibration.
Thus take for example a full tang with any kind of handle slabs, micarta, G-10, wood,etc. The full tang will transmit the vibrations directly to the usually thin slabs and of course to your hands. Net result; OUCH! A taper tang with bone or wood handle will have to transmit the vibrations through considerably less dense/more fibrous material and thus the vibrations are reduced, not eliminated of course. This is why the Nepalese khukuri's feel to have less vibration during impact than other khukuri's.
If you are making a custom knife and you plan on doing serious chopping, but want a full tang, then you must select more than one material to dampen. For example, full tang knife with micarta slabs screwed on. What you do here if you want to reduce vibration is insert a thin layer of neoprene or kevlar sheet(less than 1/8 inch thick) and this will lessen, not eliminate, vibrations. You never see this because most people don't care about the vibrations since chopping is not their biggest concern. Of course a good shooting glove will do the same thing.
You may mention then why do kraton handled knives still hurt when I chop with them. Well, because they are usually full tang and the kraton is very thin. This offers very little vibration dampening. But hell, what do I know. I'll go back to being V.P. of humor.
