Vibratory tumbler??????
Has anybody used one of these to clean up there blades after HT?
I REALLY want to stay away from Bead Blast finish and wonder if this may be a viable option. They are in pretty good shape just discolored.
Doing some S30V blades so Satin finish is out of the question.
Robert,
Why is a satin finish out of the question? S30V satins pretty nice.
Have you tried the ceramic bead? Leaves a really nice finish.
I have used a tumbler and just didn't like the finish.
Kit, I've been meaning to ask you, what is the name of the blast media you use, and where do you get it? I know you mentioned it once before, some months ago, but I can't find the post.
Thanks.:confused: :D
tumbulers are for reloading brass! i take s30v to a x45 norzac then a heavy scotch brite then a medium. i have used the heavy to take the heat treat colors off first also. play with it.
Mike,
Fusco Abrasives, 800-899-3872, B-60, SEPR Ceramic bead. Expensive but it last forever. No dust, leaves a finish that will bead water. Almost a French Gray finish.
Unlike glass bead which leaves a star shaped cut in the steel, it leaves a round dimple finish.
Let's see what some of the makers that have started using it says..
Glass bead has a recycle of about twice then it shatters. This stuff has a 20-25 recycle times and then just disappears. A 5 gal bucket of glass bead used to last about a week. This ceramic lasts about 6 months. Requires a lot less CFM of air, but doesn't hide anything.
Kit,
Hey thanks
Actually I was going by an ASSumption. After hearing one of the other makers say it was really hard to get scratches out of.
My blades were finished to a 400grit before HT and the HT pretty well cleaned them up.
I will try a Satin finish on one and see where we stand.
What kind of finish did the tumbler leave?
There are heavy duty Vibratiing tumblers that use abrasives inpregnated in a plastic media. That is how they deburr some tooling in the tool and die industry. A brass tumbler works well for its intended purpose, but lacks the power of the industrial ones using abrasive media's.
Vibrating tumblers are used to grind and polish agates. A LOT HARDER THAN STEEL.
You can get different grades of diamond powder and media .
In fact I have some and a small tumbler. I will through a small blade in this weekend and post some results as soon as I have something.
Take Care
TJ Smith
Hey thanks TJ.
I am considering buying one of the heavy duty ones that hold about 3-4gals of media. They Vibrate like a son of a gun, but parts come out clean as a whistle. The industrial abrasive media come in all kinds of shapes and grits. They run about $375-400 so it would be nice to see how it works first.
Originally posted by RHINOKNIVES
tumbulers are for reloading brass!...snip...
You'd be surprized what a real tumbler can do. I've seen raw, as cast work come out clean. It just depends on what media you use, and how much HP you have behind it!
I have NOT done knife blades (Heck, I'm only on my 2nd knife), but I deburr parts coming off my lathe all the time - a little ceramic deburring media, run wet, for 24 hours is just the ticket
Take Care
TJ Smith
OK my tumbler is not big enough to hold the blade so it is covered with media. my tumbler was 1/2 full of 600 diamond mixed with a corncob like filler. The knife only ran the tip or about 1 inch in the media. It did start to clean up and i didn.t notice any difference in surface area. I ran it dry.
I think it will work The trick is to work out the grit size. 2 knives at a time only tend to smash together. Like using a vibrating marker.
Deffinitely going to put it on the list as a way to finish blades.
Not much help
Take Care
TJ Smith:(
:D I tumbled agate and other stones as a kid and know that you can deburr with the right medium. the one thing to remenber is that if you want to have crisp grinds i don't think the tumbler will be the way to go. my 2 cents
