- Jul 8, 2018
Thanks yall.
Same for me. If I were limited to only carrying 1 knife it would be a SAK. Right now as I type this I have a Vic Executive in my left pocket which I always carry everywhere everyday no matter what kind of larger knife that I may have clipped in my other pocket. I may go days without using the larger knife but the little Executive gets used multiple times per day either filing down a broken fingernail or using the scissors to cut or clip something. The tweezers are very useful as is the toothpick. If I encounter a small cutting chor I use the Executive's blade rathar than using and dulling the larger "clip on" knife's blade. To me the little SAK is indispensable.
...But to exaggerate and say SAK's go dull after one or two uses is pure bullhocky. I've seen people who say this and when I look at their knives, they have done a botched up job of sharpening in the past and put way to steep an angle on the edge. I've seen more jobs of poor owner done sharpening screwing up of edges and then they blame the tool. If the thing goes dull after one use, the last amateur hour shaping job you did is more to blame.![]()
I would say that any knife steel could be dulled on just one job depending on whats being cut. I don't care what your blade steel is if you use it to cut something like drywall it's going to dull quickly. I've used my SAK One Hand Trekker to cut up a large amount of cardboard and it would still shave arm hair so I'm pretty confident it will still "fly through a pork chop" also. SAK's are not as bad at edge holding as some people make them out to be.I like to be able to cut a bunch of boxes into pieces (not just cutting tape and folding it) and have it still fly through a pork chop or plastic wrap. Or, put another way, it shouldn't need touch-up.
Plain edged Trekker or (the standard) serrated? 'Cuz it makes a difference.I would say that any knife steel could be dulled on just one job depending on whats being cut. I don't care what your blade steel is if you use it to cut something like drywall it's going to dull quickly. I've used my SAK One Hand Trekker to cut up a large amount of cardboard and it would still shave arm hair so I'm pretty confident it will still "fly through a pork chop" also. SAK's are not as bad at edge holding as some people make them out to be.
Plain edge. I'm not a big serrated fan.Plain edged Trekker or (the standard) serrated? 'Cuz it makes a difference.
It also makes a difference that a Trekker's blade is much longer than a typical 91mm Sam's.
Absolutely agree. Since they have been around for over 130 years now I would say their products are adequate and work for 99% or more for most people. The only people i know who say their steel is too soft or their products perform poorly are steel snobs. These are the same people who just a few years back were praising S30V as a super steel but now say its merely adequate since stuff like S110V and REX 121 have come out. I've used some of these new super steels as they're called and I can say this, they do keep cutting and cutting but, they can be super chippy. For example I once used a Vic Trekker's blade to open a can of soup. The edge was turned and rolled in several places and certainly would no longer shave arm hair but about 15 minutes on my diamond flat stones it was back to hair shaving condition with no visible damage to the edge. I did the same thing on another can of soup with a S90V blade and the edge was so chipped out it looked like a serrated edge. I had to bring out the Apex Pro sharpener to repair the edge which took well over an hour of hard work. So which is better? A blade steel that holds a decent edge and is very durable and easily sharpened and repaired or one that holds an extreme edge but is brittle and much much harder to sharpen and repair? For me I will take the more durable steel everytime.Truth of the matter is that Victorinox's steel used in SAKs and its heat treat are more than adequate for 99% of needs of those carrying pocket knives. Even 99% of knife snobs' needs. They're a great company making iconic products with the model of what quality control should be. Buy and use them with confidence.
Great post.Absolutely agree. Since they have been around for over 130 years now I would say their products are adequate and work for 99% or more for most people. The only people i know who say their steel is too soft or their products perform poorly are steel snobs. These are the same people who just a few years back were praising S30V as a super steel but now say its merely adequate since stuff like S110V and REX 121 have come out. I've used some of these new super steels as they're called and I can say this, they do keep cutting and cutting but, they can be super chippy. For example I once used a Vic Trekker's blade to open a can of soup. The edge was turned and rolled in several places and certainly would no longer shave arm hair but about 15 minutes on my diamond flat stones it was back to hair shaving condition with no visible damage to the edge. I did the same thing on another can of soup with a S90V blade and the edge was so chipped out it looked like a serrated edge. I had to bring out the Apex Pro sharpener to repair the edge which took well over an hour of hard work. So which is better? A blade steel that holds a decent edge and is very durable and easily sharpened and repaired or one that holds an extreme edge but is brittle and much much harder to sharpen and repair? For me I will take the more durable steel everytime.
A week later a new Victorinox pioneer arrived in the mail. I was blown away. Totally unexpected. Outright abuse admitted and they still sent me a new knife.
just like gaming computers, they come out with a better one each year, but to be fair, many steels that are over 10 years old and more are still decent, in my opinion anyway, for example. 8Cr13MoV, i have since abandoned that steel and all others related, but in one of my past jobs i abused a folding knife in that material and it put up with me, later gave it to someone there when i left the company. maybe i was lucky, but it was the kershaw brawlerNot too long from now, S110V, M390 and all the super steels of today will be seen by many in knife-related forums as "junk steels"
Even with a clip knife in my pocket, I would still feel "naked" without my SAKs with me, because no matter how good a single-blade knife is, in comparison it's still a one-trick pony compared to a good SAK.
Jim
