BTW, your assuming that a through hardened blade is actually going to break during use. I suggest you try it. .
I did, I dont have it on video but I have found that a blade that I hardened too much broke right away in a pre-test of my torque wench clamp.
I made the clamp based on a photo I once saw in BLADE mag.
However Im not a welder and so I didnt trust my welding on the clamp to hold during the test.
I also used two bolts to hold both sides of the clamp onto the knife blade, but I had to use the smallest bolts I had because they fit the biggest holes I had drill bits to make.
While getting ready to do the test I did a dry run of my torque wench and clamp to make sure they would stand up to the task.
I had a annealed blade of 52100 that had a bad tang that I gave up on, so I decided to harden it and use it to work out any bugs with my torque wrench setup.
But rather than going to the trouble of waisting O/A gas for the torch, I just fired up my forge and heated the whole blade.
Then I dunked the whole blade in the quench oil.
It snapped right away.
Thank GAUD I had been warned about how to do a test and so I was pulling the torque wrench down to me at the time.
Had I been pushing the wrench over the top of the vise I might well have stucked the broken blade into my chest...
I understand that some guys like to fully harden their blades, I just think that for a working man who might face jobs where they will need to put their blades to the same torque as I have, that a stronger back spine that will bend rather than break is needed.....There is no question now after my testing about it in my mind...
Now the idea that you fully harden a blade because you dont want it to bend very easy , well, to me thats crazy.
Im not really interested in the blade not ever bending, IF that means that i raise the risk of the blade snapping on me too.
I have been reading over the past year on the forum that some knife makers like to use a design that aims for a blade that is fully hard because they dont want it to bend as easy of a edge-only hard blade.
And yes, I understand that a fully hardened blade is harder to bend than one thats edge-only hard.
But so what?
It only figures to me that if I made the whole blade just as hard as I made my cutting edge, that the blade would be a lot harder to bend at first..
But, again so what?
The more important matter is that the same problems we all have with the hardened edge being more easy to chip, crack and snap would just get carried over into the rest of the blade too.
Well who wants that?
Thats not the direction I am going...
I want a blade that can cut to be sure, so I need a very hard edge.
But a blade you also can trust will not snap on you just because you over-torqued it and the edge has chipped or cracked .
Bends I can fix with a hammer....
Cuts from a broken blade?,,,not so much.
So do I believe I should design my future blades to bend?
no.
I believe the bending is just an effect of the true design aim, and thats to make a blade that will not snap on a guy.
Bending just seems to me to be an outward sign of the inner nature of where the steel is at.
I dont design my blades to bend.
Bending is not my real goal.
I have never needed a bent knife on my job in my life.
But what I have always needed is a knife that can cut, and that will not let me down in a pinch...I need a knife I can trust will not snap in two on me just because I pushed it over the limits...
because I will always be pushing the limits, thats what working men do.
We dont just torque on a blade untill we think it's about to break,,,
we dont stop short of the designed limints of the steel...
We go for it,
we use the tool in ways it was not meant to be used...
Thats the way normal life is for a knife.
