This may not be fixed by tightening down screws, the screws may need to be moved, or some other design change made. The issue seems to stem from the use of a ball (well, the initial issue is beating on a knife, but that's just what the test is) By using a ball, the contact surface with the liners is as small as possible, practically tangential. This creates a lot of pressure at the point of contact. Couple that with the smooth continuous curvature, and the liners can 'flow' around the surface of the ball once they have begun to spread due to the extreme concentration of force at the points of contact.
If the thickness of the liners, the distance of the pivot and assembly screws from the lock ball, and the depth of the contact area between the ball and liners is not optimized for this type of ab/use, then the liners will begin to deflect/flex, the ball will embed between the liner surfaces instead of in the milled slots, leverage will increase along the surface of the ball, and the liners will be flexed/bent further.
I don't think it would be too difficult to 'fix' if Spyderco feels the need to beef up the folder. Thicker metal on the liners (at least at the lock interface), adjust the way the top ramp is mounted to aid in keeping the ball captive.
Still, if you look at the most popular Spydercos, they aren't going to fall into this sort of activity, and are still bought without fears. And we still need to ask ourselves, or wait for video, of the 'hard use' series of knives, like Emersons, Striders, Hinderers, ZTs, etc. and see how much better liner & frame locks do.
