- Mar 1, 2010
Obtuse edges can be reprofiled, thick tips can be thinned but thin tips and fragile blades will be hard to thicken. Also thicker can still cut maybe with difficulty but thin tips and blades can never be hard use.
I assume a XM-18 could take the same hard use/abuse? Anyone?...............
It cuts well enough in the video. It's just not an uber thin pocket scalpel.
You are essentially correct. Spyderco's are the best slicers, bar none. They also have the sharpest tips. It's a matter of design philosophy.
It should be immediately clear that these advantages are also huge disadvantages if the knife gets subjected to hard use or even abuse. I own a M1 too, and its tip is delicate too, compared to an SMF or XM-18.
So the question for the prospective knife buyer should be, what is more important to me, efficiency at cutting and slicing, or toughness of blade and lock?
It hasn't been reprofiled yet.![]()
Be careful, Jim!
With the latest warranty policy change it may not be covered after![]()
Hey Ankerson,
When are we gonna see that custom Demko go through this?:thumbup:
It would be like running over a VW with a tank.
The Custom is 5X stronger than the AL. :thumbup:
here are some side by sides - Strider, Manix 2, Lawman. I can do others, or take these down, either way. I only recorded 3 at once, figured more would be too much to follow, esp. at the resolution. And the advantage the M2 has in the cutting is ridiculous.
I haven't done any formal comparisons, but I can safely say that of all the folders I own (over 60) the Spyderco's/Byrds are the best cutters/slicers, and the only knife that falls into the same category is the Benchmade Onslaught.And the advantage the M2 has in the cutting is ridiculous.
I second that. I feared, Jim might get tired from cutting and quit, before all the tests were done, or time was over before the stick was through.Compare the Strider to the Spyderco on how well it cuts up that stick. No comparison. Half the time, the Strider is just sliding along the surface or unable to get a good bite.
You can´t change a truck into a sports car but a little compared to what is sometimes delivered from the factory. That´s were a convex grind comes into play.
I've been meaning to ask Ankerson:
Did you keep track of whether or how much the lock bar traveled after the testing (on both the RW1 and the 0300)?
