Vortex Strikefire II / Comps / Holsters / Flashlights
Feedback: +95 / =0 / -0
Sale Terms:
  • US shipping only
  • First Class shipping unless otherwise noted
  • Paypal Purchase of Goods Option (no gift payments please)
  • I reserve the right to refuse sale at my discretion
  • No trades/No Proxy Buying
1) Vortex Strikefire II [Sold to avphred] $135 ships priority
2) Griffin Armament 9mm Micro Carry Comp [Sold] $35
3) Cyanide Design mini-ROOK 9mm Comp [Sold] $60
4) Beretta Nano: PJ Holster Tuckable IWB Kydex Holster
5) S&W M&P9c: PJ Holster IWB Kydex Holster
6) S&W M&P9c: Tulster Holster
7) Kahr CM9: PJ Holster Tuckable IWB Kydex Holster
8) Kahr CM9: PJ Holster Tuckable IWB Kydex Mag Holster gone
9) Kahr CM9: Kholster Tuckable [Sold] $15
10) Glock 26: White Hat Holsters MaxTuck Tuckable IWB Kydex Holste
11) Glock 26: PJ Holster Tuckable IWB Kydex Holster
12) Glock 26: Tulster Holster
13) Glock 26: TXC X1 Holster
14) Oveready Triple v5 E/Scout Head XPL 3000K +Amber with Malkoff body
--14a) Part out Oveready Triple v5 E/Scout Head XPL 3000K +Amber $245
--14b) Part out MDC 18650 to E-Series Body × 1 $75
15) Mateminco TK01vn NW XHP 50.2 modified by Vinhnguyen54
16) EagTac D25LC2vn SBT90 5700K De-Lens modified by Vinhnguyen54
17) Thrunite T10vn II, SBT90 5700L De-Lens modified by Vinhnguyen54
18) Convoy M2vn Oslon W2 modified by Vinhnguyen54
19) EagTac DX3B MINI Pro XH-P50.2 NW
20) Fenix E16 NW (discontinued) [Sold] $35
21) Convoy S11 / BLF Special Edition Combo
LNIB - has been opened and handled but never mounted.
Red Dot / Green Dot. Has 4 MOA Dot only. 300 hours battery life on highest setting, and up to 5,000 hours on lowest setting. 10 brightness settings with no true night vision settings. Red dot here is much brighter than the green dot. Lower 1/3 Co-Witness Mount. Includes all original box, tools/accessories/mount.
Complete photos:
https://imgur.com/a/0i2Iz9L
2) Griffin Armament Micro Carry Comp
LNIB - has been opened, handled and threaded on to a 1/2 x 28 threaded barrel, has not been fired through.
Features:
· 17-4 Stainless Steel
· Compatible with any threaded barrel in 1/2 x 28
· Black Nitride finish
· Wrench flats for easy installation
Will universally fit on a 9mm threaded barrel (both 1/2-28 and M13.5x1 LH), including pistol caliber carbines (PCC). Using a set screw free design, can be repeatedly taken off and installed without damage to the barrel threads, allowing for easier cleaning and maintenance.
Handiness: Right Handed.
Belt Width: 1.25" (I can get this over my 1.5" belt)
Belt Attachment Type: Over the belt clip on Loop
Holster Cant: 15 Degrees
Tuckable: Yes (shirt can be tucked while conceal carrying)
Complete photos:
https://imgur.com/a/rKj6p
Belt Width: 1.25"
Belt Attachment Type: Over the belt clip on Loop (clip reinforced/thicker than standard)
Kydex Thickness: 0.80"
Tuckable: No
Complete photos:
https://imgur.com/a/FfgNI
Belt Width: 1.5"
Adjustable Cant: 0-30 Degrees
Tuckable: No
Complete photos:
https://imgur.com/a/wmaxN
Handiness: Left Side Carry, Bullets facing backward.
Belt Width: 1.25
Belt Attachment Type: Behind the belt J hook (IWB only)
**magazine not included
Complete photos:
10) Glock 26: White Hat Holsters MaxTuck Tuckable IWB Kydex Holster
Complete photos:
https://imgur.com/a/SMVpE
Belt Width: 1.5"
Tuckable: No
13) Glock 26: TXC X1 Appendix
Frontside Color: EMT Red (Bright)
Backside Color: Black
River Color: EMT Red (Bright Red)/Black
Concealment Wing
Dual Clips
Emitter: XP-L (3000K warm white with Amber secondary).
Purchased new and never carried. Comes on an unshrouded Malkoff MDC 18650 to E-Series Body.
Programming can be done via a web video interface through Lux-RC. Link and instructions will be sent upon purchase.
15) Mateminco TK01vn NW XHP 50.2 modified by Vinhnguyen54 $110
Tank of a light with a nice 4000K tint and Stock UI (moonlight, low, medium, high, turbo). Includes a protected 21700 Acebeam battery that utilizes on-board charging, 18650 battery spacer, lanyard, and box.
CW Tint with great output and throw for it's size. Uses DriverVN4 Programmable Driver/UI. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes box, high drain 18650 battery and accessories.
CW Tint with great output for it's size. Uses DriverVNX2 Programmable Driver/UI. Includes box/tin, high drain 14500 battery and accessories.
Emitter: OSRAM OSLON White2 (6500K cool white).
This was modified by Vinhnguyen54 @ CPF and direct from him. Strike bezel was heat treated and Vinh added his FS54 forward clicky switch. Uses the programmable VN4 firmware. Includes a high drain 18650 battery, and grip ring. Nice clean and white beam with good throw. Approximately 1000 lumens.
Nice small/medium neutral white EDC. Includes box, EagTac 18350 battery, 18650 body, charging cable and brick.
Nice neutral white EDC. Includes rechargeable battery, box.
Convoy S11 uses a warm white emitter, believe an XHP50. 4 modes (low, medium, high, turbo). There is a preflash on low. Includes a rechargeable 26500 battery.
BLF light can switch between 4-7 modes (currently set on 7 modes). Short half press advances modes forward, long half press reverse mode order. Nice neutral white light with decent throw. Needs an 18650 battery.
