Nope…. 2 knives are coming in the mail from Europe, another two, next week. I’m planing on Police 4 in K390 with some CF scales, and if Magnacut shows up on Manix of some sort, I’ll get this one too.
Have you heard of the Cruwear Boker slipjoint?I've become picky about my purchases, I want magnacut in a slipjoint and a small EDC type fixed blade. My current favorite folder is a traditional made with modern materials: Viper sowbelly stag with titanium bolsters and M390 blade steel. I see Lionsteel has a folder coming in magnacut, maybe they'll put it in one of their slipjoints too.
Basically a stainless version of 4v. Unfortunately, a factory grind won't bring out the best properties of this steel other than it's corrosion resistance. It's not going to impress someone who really wants wear resistance as their primary goal. What it will do is allow custom makers to run their knives extremely thin at the edge and very hard. A well made magnacut custom will be able to utilize geometries that m390 won't be able to dream of, and have exceptional edge stability.I was in the pass around with the Spyderco Magnacut Mule and it didn't impress me as being much better than other modern steels.
I'm not sure what all the hype is about? Anyone want to let me in on the secret?
I think most of you (not all) are missing the point, Magnacut performs just like 4V (which I’m sure you all know is a great steel) but it’s super stainless so practically no maintenance. Sure there’s other steels that perform the same or better in one category, but again that’s not the point, it’s having really good performance from all those categories in one steel.
I personally can’t wait to start using it on my custom fixed blades!
At least for the salt series, it'll revolutionize cutting performance the same way lc200n did when H1 salts were upgraded. Lc200n is highly stainless, but it really lacks performance in edge retention. With magnacut you have a steel that is 95% as corrosion resistant and yet has significantly higher edge retention. The only other steel in the highly stainless class which compares to magnacut in that regard is vanax which is impractical to put on a production knife due to expense and supply issues.I don't think anyone's missing the point. I think the usecases wherein Magnacut will outshine other knives in cutting performance are going to be extraordinarily tiny amongst the normal EDC and cardboard cutting use crowd that frequents this forum. There are plenty of steels out there that do entirely great at those kinds of things. "But it's stainless!!" I mean, all due respect, but....and? I myself live in a humid environment, and have never had a knife in a modern "super" steel rust on me. Not once. But then, I also tend to wipe my knives down after use, so there's that. That's why you're seeing so many comments along the lines of "I don't see what the big deal is". Many of us here have so many knives that cut exceptionally well, I won't speak for others, but I cannot think of a usecase in my life where it would be better if my knife was made of MagnaCut instead of S35vn/Cruwear/XHP/etc. If I want a non-rusting water knife, I've already got a few Spyderco Salts stashed around, and I've never had an issue with any of them failing to perform. So, as far as I'm concerned, I don't have any issues in my knife-using experience that MagnaCut is going to come save me from. Your mileage may vary.
Hey, maybe I'm crazy, and we're going to be seeing MagnaCut knives with edges at like, ten degrees inclusive or some nonsense that can turn a refrigerator box into ribbons and still shave hair, but I candidly don't think so.![]()
If rust isn't an issue at all for you, you won't see any difference between magnacut and cruwear... magnacut was designed to take the properties of the tool steels in the cruwear/4v/rex 45 class of steels and add stainlessness there. But rusting is a concern for some people and for them this will be a great addition to Spyderco's lineup. As for the comparison between magnacut and s35vn/xhp, those are not really comparable classes of steels. Magnacut is basically an upgrade on s35vn in every way... tougher, runs harder and holds an edge longer while being almost as easy to sharpen. I would argue that XHP is just not comparable to magnacut since it's got very different properties. It might have a bit more edge retention than magnacut, but it's nowhere near as tough, can't get as hard and isn't a true stainless steel. It's got 2.5x the carbide volume of magnacut... so I'd expect it to hold an edge longer at a significant sacrifice to edge stability and toughness.
The Spyderco mule is ground to 0.025" behind the edge, and run at 62-63 HRC. At those parameters, the properties other than toughness and stain resistance aren't really going to stand out compared to m390, s35vn etc. But if you have a good custom maker make you a knife at 0.007" behind the edge and 65 HRC, all of a sudden it stands apart from all other stainless steels. And even at 65 HRC, it should have the same toughness of s30v at 60 HRC. Are we ever going to se a Spyderco ground that thin and hard? I doubt it, but never say never.
Can anyone explain these ratings to me? These are directly off of Alpha Knife Supply Steel Charts.
They state that the Maximum is 100 and Minimum is 0. So, I assume the higher the number the better the rating.
Am I missing something here?
Ratings: AEB-L
80 = Maximum Toughness
44 = Maximum Edge Holding
Ratings: CPM Magnacut
33 = Maximum Toughness
56 = Maximum Edge Holding
Ratings: CPM S35VN
20 = Maximum Toughness
51 = Maximum Edge Holding
Ratings: CPM 154
18 = Maximum Toughness
47 = Maximum Edge Holding
This to me is where Magnacut really seems to shine. I use my H1 Catcherman for all my salt water duties, but I've never been impressed with it's edge retention. After a day of use fishing, I've always had to sharpen it. Even when I was using it for waterfowl, it would get dull after processing a few birds.At least for the salt series, it'll revolutionize cutting performance the same way lc200n did when H1 salts were upgraded. Lc200n is highly stainless, but it really lacks performance in edge retention. With magnacut you have a steel that is 95% as corrosion resistant and yet has significantly higher edge retention. The only other steel in the highly stainless class which compares to magnacut in that regard is vanax which is impractical to put on a production knife due to expense and supply issues.
Ratings: AEB-L
Ratings: CPM S35VN
Ratings: CPM 154
