Walking Dead Folder Prototypes!!! . . . . Coming Saturday, January 31, 2026, at 5:00 PM Eastern.
Jerry Busse
Moderator
Walking Dead Folder Prototypes!!! . . . . Coming Saturday, January 31, 2026 at 5:00 PM Eastern.
Here is a VERY Unique Opportunity For Serious Busse Collectors.
The WD-38 was made back in 2013 for the Walking Dead TV series. They were NEVER released to the public.
It is important to note that there are a number of small variances in design and finish within this small batch of prototypes. . . . These prototypes are NOT all the same.
These will be available in 2 versions: Custom Elite Version and the Blind Bag Prototype Version
If you want to know exactly what you will be receiving, then you should order the Custom Elite Version, which allows you to choose nearly every option available, for $1297
If, however, you choose to go where so many HOGs have blindly gone before, then you can choose the Blind Bag Prototype Version for only $427
How To Order:
These are being offered Ganzaaa Style and are being sold, first-come, first-served, starting on Saturday, January 31, 2026, at 5:00 PM Eastern.
Starting at 5:00 PM Eastern, (No Earlier) you must email both Becky, at becky@bussecombat.com and Garth at garth@bussecombat.com with your real name and contact info. You must include which Version you want, (Blind Bag, Custom Elite, or both) along with the quantities of each desired.
The office will start contacting those who scored early next week.
Info about the Blind Bag Version:
There are no special requests on the Blind Bag Version . . .
Some have slightly heavier springs than others, and require that you use a two-finger pinch on the lock button to open it, while others were made with lighter springs that could be opened with a quick flick of the knife.
There are, likewise, a number of different belt clips in both shape and finish. . . .
The INFI blades are heavy-duty and approximately .160" thick.
Some blades have hand-ground flat or hollow bevels, while others feature our Corrugated bevels.
This is an INFI HOG Only Offer!
If you are not an inducted HOG, you may want to get an email off to Becky ASAP to see if you qualify for HOGdom!!! . . . .You can email her at becky@bussecombat.com
Blind Bag WD-38s Are Non-refundable. No whining allowed. There are NO special requests allowed on the Blind Bag Version. You get what you get, and you like it. 😄
Blind Bag Prototype Version:
What you can count on:
INFI Blade (3.8" Long x .160" Thick)
Ball Bearing Pivot
Titanium Handle Slabs
Hardened Stainless Steel Armored Plates
G-10 Spacers
Busse BLOCK Lock
What is random:
Blade Finish: (Mirror Polish, Satin, Stonewashed, Double Cut, BIG (Busse Industrial Grade) or Cerakote)
Handle Finish: (Satin, Stonewashed, Double Cut, or Cerakote)
Armor Plate Finish: (Aged, Mirror Polish, Satin, Stonewashed, Double Cut, or Cerakote)
G-10 Spacer Color
Spring Tension: (Ranges from light to heavy)
Screw Heads: (Button Head Torx, Custom, or Philips Head)
Bevel: Flat Hand-Ground, Hollow, or Corrugated
Thumb Button Design
Pocket Clip: Design and Finish
Thumb and Grip Grooves
Here are the pics:
Random Stack Of WD-38s
On Hand
In Hand
Stepped Lock Button With Custom Screws
Corrugated Bevel, Flat Lock Button, Blade Stud (No Blade Hole), Double Cut Blade with Satin Finished Armored Plate
Random Belt Clips
Aged Finish On Armor Plate. BIG Finish on blade, Light machining marks on Blade, plain belt clip.
In Hand
