Walking stick / hiking stick / hiking staff - What do you use?
I use a stick I purchased at an Arkansas State Park.
It stays in my camper.
I've been thinking about maybe getting one of those Cold Steel staffs.
That being said does anyone have any experience or opinion on these?
Survival Staff - Crawford Knives
They seem to be a walking stick survival tool in one, including a blowgun.
I have two Cold Steel walking sticks.
> a Walkabout stick. Polypropylene.
> a Heavy Duty stick. Heat treated 6061 Aluminum alloy with a plastic handle.
Both sticks are 37 1/2" long. I'm 5'8" and wear a 30"inseam pant. I cut both sticks so that they are ~35 1/2" long including the rubber tip..
The Walkabout stick does not have a rubber tip, so as it comes from the factory, it slips on concrete. I added a rubber tip.
The Heavy Duty stick, comes with a rubber tip, but it's not the correct grade of polymer for that purpose. I replaced the tip.
I find the Walkabout stick to be durable and usable, but heavy. Much heavier than my wooden walking sticks.
I find the Heavy Duty stick to be very light, and the handle to be comfortable, YMMV. But the handle is polypropylene and it is not sufficiently tight in the body of the stick, so it has a tendency to rattle when I use it. I tried injecting silicone sealant into the joint and that helped. But it still rattles a bit, which I find annoying.
In short, I prefer my wooden stick to the Cold Steel sticks.
Regarding the Crawford stick. Check your local laws. Several states, including mine, have laws against hidden weapons or against knives which are disguised as other objects. Also, I see no benefit to the design. I always have a knife on me (Duh) so I don't need an extra fixed blade. And I have no desire to go hunting. It looks to me as if it's an answer in search of an actual need.
Note: beware of shipping charges when purchasing sticks. The freight can be as much as the stick, depending on whom you buy from.
Thanks for the info on the Cold Steel products, I appreciate the insight.
As far as the Crawford stick, I'm not sure I see it as something with definite utility. Especially at the advertised price point.
It seems to be novelty more so than practicality.
I'll definitely watch out for the shipping charge .
All good info, thanks! 👍
My stick and cane review here
A lady on one of the trails in Glacier NP talked my wife into needing hiking poles. It seems my wife slips, trips, and falls more with those damn poles than just hiking. I have tried to get her to try using just one, but no luck. Plus she is soooo slow now. I believe they are adjusted properly. They are high quality. She is almost a year into this project and still looks like a noob hiker out there. We aren’t expert hikers, but we do have many, MANY miles on the trails. Any advice? I almost want to make them disappear… but she will buy more!
She is holding them too close to her body.. The poles should angle away from her while hiking.. I had a little trouble tripping over them and found this helps.. I got a pile of miles this way and no more tripping..
Tell her to spread out a little with her arms..
Hope this helps.. It did for me..
You kinda gotta flow with them and not worry about placing them as time goes on..
John
Recently purchased this Hawthorn by Brazos. It is 58" and was the cheapest of three available lengths. I will probably just cut it down some at the top and drill another hole for some paracord. I am 5' 10" - it has a nice knurly thickening right at my gripping point (to the right of my hand in the last photo). Just checked, and the 58" is now even cheaper - about $6 less! I think I am going to buy another and maybe shorten that one to about 48", maybe a little less.
Well, I did buy a second 58" Brazos Hawthorn and at just under $30 and free shipping a steal. It came minus the rubber tip, and was dusty like it had been sitting in a corner for a very long time. But that's ok - remarkably straight for almost it's entire length. So now to decide which one I want to keep at 58" and which to shorten.
Another Brazos. This time it is rustic wood twisted hickory. Looks beautiful. Ladies in the family will be happy using it. :) I put Brazos spike on it as it enhances what a stick could do as a tool and sure extends the tip durability.
She approves too 😀
dasylirion wheeleri (Sotol)
This stick is 7 feet tall and weighs 5.5 ounces. The top is about 1 inch wide and the bottom 1.5.
Its at least 10 years old. All did was cut off the ends and used my knife to scrape off the leaves.
You could easily sand it and coat it with shellac or some such.
Those are light and strong. I have used them for a spindle and base for friction fire to very good effect.
I really like all the beautiful wooden sticks on this thread too.
For decades I used a pair of Black Diamond Alpine carbon fiber poles. But in recent months needed something more supportive for my cranky IT band for my right leg. I have had a Leki Wanderfreund for when I sprained an ankle occasionally. I upgraded to the newer version with speed locks for quick adjustment when changing footwear. My orthotics raise me up taller when I’m hiking so the walking stick needs a slight adjustment for best performance. This worked so well and got me back into wilderness that I sprung for the carbon fiber version that only weighs 8 oz and has a thicker and slightly more comfortable handle. Took that for a test spin today and am very pleased. I love desert immersion but age is trying to slow me down. These walking sticks are money well spent.
Did your wife try my suggestion?? Was hoping it would work out for her!! 👍
John 😁
A Huntsman, a Hiker, and a Camper walked onto a bar...
...a gravel bar.
The Huntsman is my pocket partner today, as I continue to whittle on my latest walking stick creation - "Spirit of Dantal" - Ref: A Google search for "The freshwater pirate of Lake Geneva".
Spirit of Dantal seemed an appropriate name for this walking stick since this fellow showed up while I was whittling on it with my Swiss Army Knife. Seriously, I didn't carve that, it just materialized while I was cleaning out pith and removing bark.
The only tools to touch this stick - a Swiss Army Walnut Huntsman and a primative sanding tool. My intent at this point is to use no more than the SAK and some natural rock pieces to finish it before applying Boiled Linseed Oil.
It's beginning to take shape.
As discovered last September while wandering around the wetland down by the riverside.
I figured I'd stand it in the corner of the covered back porch of the house and "listen to the stick" for a while to see where to go with it.
I just had a feeling there was something hiding in there.
Be safe. Enjoy life.
