- Nov 1, 2000
For The Loss?
Original meaning was Continue Mission -
uck The World
I've experienced a dramatic uptick in orders since my 1x42 died in July and I started running my 2x72
I've never handled a chisel grind, symmetry appeals to me more. Maybe though I just need to give it a chance.
I will need to acquire a chisel grind at some point. Not going to pretend I would use it much, but I still want it!![]()
Several variations on the chisel grind. Zero bevel, secondary bevel, asymmetric, and Besh Wedge.
As for grip dislodge during a cut, the forces exerted are transferred to the media being cut. Never had an issue with this compromising grip.
Not a fan of the chisel grind unless it's a chisel, but glad to hear your business is doing well.
For The Loss?
Original meaning was Continue Mission -uck The World
This is true. My ultimate test of sharpness is when I cut myself and don't notice until I see the blood.If your tomatoes are screaming, your knife is too dull.
I have read this several times, and I think that you are saying that I need to double the angle on the bevel side of a chisel sharpened blade which of course would not improve (reduce) the inclusive edge angle, and I would not enjoy the benefit of a very acute (razor like) edge.
I have right and left side chisel sharpened blades. Their included angle is 15 degrees. In use, they behave like scalpels except that it is hard to change direction when cutting. They want go in a straight line. As such, they are great for making uniform slices (sushi, ham, lunch meat, roast beef, etc. A right hand bevel is useful for large cuts where the slices are falling off to the right (I am right handed). A left hand bevel is more useful for small controlled cuts where the lopped pieces are coming toward me (maybe cutting cooked chicken or steak on a plate).
If you want to have a little leeway in changing direction while cutting, choose the double bevel. If you want to go nuts on direction changes while cutting, opt for the convex edge.
I would like to mention that you make an awesome chisel ground blade, your Riptide I grabbed in 2012 is a laser!
FlatIs your chisel grind flat or slightly concave on the back side?
This is why I personally like using right-handed chisel grinds as a right-handed person. It maximizes what they do best as cutting surfaces (even if it also maximizes what they do worst as cutting surfaces). If I'm going to go chisel, I'm going to go all the way. It's what turns me off Emersons as a right-handed person. All those left-handed chisel grinds.Something like that. Basically I was saying that it's not an appropriate comparison to compare different grinds that don't have the same included angle, for the reasons you've deduced. There's nothing "inherent" about the difference in geometry other than the tilt of the blade relative to the handle. For every chisel grind that's 15° you could just as easily make a double bevel that's 14° (7dps.) The major difference is that true chisel grinds have no relief angle on the flat, so turning them away from that face during the cut is almost impossible while turning the other way is easy. As such, they're best used for paring cuts where you're removing a thin amount of material from the surface of your target without much pushback. If you try using a "right handed" chisel grind to make long cuts in the middle of a piece of cardboard you'll find your blade is prone to drifting clockwise rather than tracking straight because the deflection acting on the blade is imbalanced.
Another difference when dealing with a true chisel grind is that your minimum angle of approach to the target is skewed per side. An edge can only cut when approaching at an angle greater than that of the edge angle (barring deformation of the target surface.) If approaching the target at an angle equal to the edge angle, then the bevel is parallel with the target and won't bite. Any lower of an approach and the bevel is now actually pointing away from the target. So, say you have two knives with edges having a 30° included angle--one a conventional double bevel, and the other a true chisel grind. The double bevel will have an edge measuring 15° per side and so can approach the target surface at any angle greater than 15° in either direction. The chisel grind is 0° on one side and 30° on the other, meaning that on the one side it can approach the target at any angle greater than 0° (which is why they're great at paring off high points on a surface) but has to approach the target at a whopping >30° on the other side. That does mean, however, that for that given total edge angle it's very easy to use that side of the knife for breaking from a cut, which cannot be reasonably done with the other face.
