I'm looking for a new chopper, and it will be a Christmas present. If this is in the wrong forum, then I apologize; I didn't see a "Wanted To Buy / Make" forum in the custom makers' section.
Let me describe what I'm looking for, and hopefully somebody can give me their thoughts...
Shape: Pretty much the knife from Rambo 4 in terms of blade shape; the handle is flat in the back and has 1-1/2" long guard which curves a little toward the hand. The last 1/2" of the butt should be exposed.
Construction: 3/16" or 1/4" thick steel. O-1 or something similar would be ideal. Fully exposed tang. Handle slabs should be micarta or G-10. The blade should keep its thickness all the way to where the tip slopes down, and it should be a full flat grind. Two lanyard holes should be placed in the butt, each 3/16" in diameter.
Measurements: 10" long blade, 2" wide. 1-1/2" of jimping on the back of the blade, approximately 1/16" deep and 1/16" apart. 5" long handle, about 1-1/4" wide. Including the scales, the handle should be around 3/4" thick.
I'll get a photo of my paper drawing on here ASAP, but that's the best way I can describe what I'm looking for. Is this something anybody would like to try?
Added: This Rambo 4 -like chopper from Walt Davis is nearly perfect, but I'm not sure about the measurements. I'd also like a guard and exposed tang on mine. Just for photo reference...
With a guard like the second knife in this photo...
However, the guard should be one solid piece, with the blade and handle.
