Wanting to build my first knife
First of all I'm new to the forum (I was directed here by someone on ArcheryTalk). I would like to have a custom hunting knife and I am thinking about doing it myself. I'm a do-it-myself type guy at times, and like to do some things myself because it gives me the satisfaction of a job well done. I have never made a knife before so I was wondering if anyone could give me any pointers and/or recommend some quality materials.
I'd like to have an antler handle but the only antlers I have that I could use are from a spike buck that I got a couple years ago. But the problem is that they are small. The bases are about as big around as a dime. I know that's too small to use for the entire handle but I was wondering if it's doable to inlay part of the antlers into the handle.
Thanks for any help you can give!!
I am new too, but one piece of advice I can give you is to start simple. I had a few ideas in mind, but whenever I posted them, I was told it would be a good idea to tone it down. Start with a flat grind, easy handle shape, and some 1084 if your going to heat treat yourself. I am glad I got this advice, because if I had stuck with my original ideas, I would probably have scrapped my knife half way through. As for the handle material. Most knife making supply websites have antlers listed under handle material. Good luck on your first knife and welcome to the forum! Also look at the sticky on how to make a knife. Lots of good info
Welcome. And as a fellow AT'er also I will pass on some general things I've learned in my limited time to just mull over in addition to the counts guide (which is fantastic). This is basically what was told to me when I first got here and has stuck ever since thanks to many of the great folks here who have helped and continue to help with me. There are a few things you're going to want to consider.
First the type of steel you plan on using. You can go with something like a high carbon or stainless. High carbon you can likely heat treat (HT) yourself stainless you'll likely have to have sent out unless you happen to have a fairly specialized shop. For high carbon 1084 is about the most forgiving you can get for a DIYer. Keep in mind there is also the possibility of having a company do the HT for you which is nothing to be ashamed of. It guarantees it'll be done right and you'll also know the hardness of the steel.
Second, think easy. There is a lot of time, blood, sweat, tears, and aggravation making a knife. And if you get addicted to it (which is almost inevitable) you'll have plenty of time to make more. The idea is you don't want to try and paint the Mona Lisa when you've never picked up a paint brush. Full tang knives tend to be the easiest, things like inlays can sometimes be done but again is a lot more advanced than making a knife. Again you can always incorporate these things down the road.
Third, fill out your profile. You might get lucky and realize someone here is close to you and might be able to help you out face to face.
Gonna stop numbering here because there is a lot and I'll probably miss some things. Draw some knives, come up with designs if you want post them on here and people will critique them if you ask. Once you have a design laid out make a mock up of one out of cardboard, or if you're ambitious wood. See how it feels in your hand there are a lot of things that look good on paper that don't feel right in the hand. Figure out what tools you have available. A knife can be built with a hacksaw, files, sandpaper, and a ton of elbow grease. Everything else just makes the job go a bit faster and allows you to make bigger mistakes quicker. Everyone wants to build their "dream" knife right out of the gate, few if any, do. The idea is like anything else.... Get the basics down, see what is involved, actually make something sharp and pointy that is functional and know what it takes to do it. Then you can perfect from there. Heck you can make the exact same knife over and over and with little tweaks here and there, different materials, etc make it look better. Chances are it will be anyway since every time you make a knife you usually learn something. Hope that gets you started.
If you want a proper piece of antler for a handle I can provide some for free. I have way more than I need, and it's pretty easy to get more since the deer shed them every year. ;)
Thank you for the replies. Through doing some online searches I have found some websites that have knife making supplies. Are there any I should stay away from because they have lower quality materials? Here is one that I found that has a blade style I like.
http://www.knifemaking.com/
The stickies that The Count linked to have a section on suppliers.
Knifekits.com is a great source for blades and kits, as well as the supplies needed. Jantz, Texas Knife Supply, USA Knifemakers Supply, Sheffield Knife Supply, and sevrearal others are good sources, too.
Hey Tank. I just made my first 2 knives from Jantz,one in D2 one in 1095. They seem to be of great quality. You can see them here http://www.bladeforums.com/forums/showthread.php/1014136-First-knife
