If they are steel they can be heat colored bronze also. It will require a controlled heat source like an oven or hot plate (more difficult to get even coloring with a hot plate) though, you won't be able to do it with a torch. Steel oxidizes with elevated temperatures and will begin to turn colors at around 400F. Starts with yellow, then bronze, then brown, blue, purple, black, IIRC. The colors will look a lot nicer if the parts are polished before coloring.
I don't know if it works with brass, but you can effectively chemically copper plate steel by putting copper in your Ferric before etching the steel. It should (theoretically) also work with brass.
Edit: Copper plated blade by etching in ferric.
