Mike Sastre
Custom Crafted Concealex Sheaths
- Mar 23, 1999
Just got several of the new Warcraft Tantos in here yesterday. 7.5" CPM-3V High Carbon steel DLC blade, with full tang, G-10 handle, and a Secure-Ex sheath that is compatible with both sizes of TekLoks. Have not done any cutting yet, but love the feel of the Warcraft Tanto. Balance is just about on the riccasso, making it feel very live in the hand, and weighted nicely for snap cuts, one of the things the Tanto design excels at. The sheath has a good fit (no movement or rattle on the one in the pictures), with a great balance of holding tension and release (can shake it upside down without losing the knife, yet draws with ease). Love this knife for its intended purpose - Warcraft!! I'll probably make a Southern Comfort for mine, as I carry most of my blades that are over 7" that way.
There's a couple things about belt attachments that you should know. I dropped the existing cordura belt loop down one eyelet to make snapping the safety strap easier (only fits around one portion of the handle). The slots are now wide enough to accommodate mounting posts, so you have many combinations using eyelets and/or slots. One thing though: BladeTech is now using smaller posts rather than the 3/8" lengths they used to use, so you will have to use the ones from the supplied Cordura belt loop, or acquire others. The ones supplied with the TekLoks are not long enough. Good news is that the sheaths are also perfect for using a Spyderco G-Clip, which is my belt attachment system of choice, and they come with hardware that works (contact me if you need any). See attached pictures.
