To be fair, that is not a warranty issue. That can be done to many knives. It should "sharpen out" eventually.I have noticed that many single blade slip joints have the edge very close to the center spring pin bump when closed. Depressing the blade in the frame will often make contact. What most people like about single blade folders is their slimness, so designing the blades low in the frame is pretty normal. Not seen nearly as often with multi-blade knives in my experience. I would contact Chris Tucker at GEC to see if they can fix it.
I don't see what the big deal is. Many knives do this, and not just GEC. If that tiny scratch bothers you, just sharpen it out and stick a bit of wood matchstick or leather shoelace in there so it won't bump the spring again. Problem solved.
Not many. This is the first knife I see with this defect (for me is so..). I like Gec knives a lot and I hope they will consider this in next productions.
Knives are not Toys. Do not play with your knives. Problem solved.
Peening a kick won't do any good, the blade is resting on the kick, when you push the blade in you're actually pivoting the blade on the kick towards the blade edge. Not a good thing to do on any knife.
Eric
