black mamba
- Oct 21, 2009
Eric, thanks for the explanation. :thumbup:
Knives are not Toys. Do not play with your knives. Problem solved.
No Meako, the actual act of pressing the blade in has little effect on the spring, probably flexes about the same as when the blade is being opened. The problem is that when you press it in past it's resting point, the only thing that'll stop it is the blade edge. Knives are not designed to account for this so of course you'll wind up with a ding in the blade If you go too far.
Eric
Not many. This is the first knife I see with this defect (for me is so..). I like Gec knives a lot and I hope they will consider this in next productions.
Eric
Yes many actually. I have seen plenty, most of which are trapper styles with stronger springs and a raised bit in the center of the spring. It is not a defect at all, just the nature of the beast, something to be aware of. It just takes a tiny bit of precautionary measure to prevent this seemingly insignificant issue.
Not toys - Tools. Taking artsy pictures of knives is also playing with them. Hell, it could fall out of that apple it's stuck in to right on to the tile floor God forbid!
Carry them, use them - and OP if you carried and used that knife lightly for a week, you would probably do worse damage than teeny nick you have there!
You forgot weapons. Knives make great weapons.
Peening a kick won't do any good, the blade is resting on the kick, when you push the blade in you're actually pivoting the blade on the kick towards the blade edge. Not a good thing to do on any knife. Eric
Actually, peening the kick could extend the kick downward so it makes earlier contact with the backspring as you close the knife, thus lifting the edge away from the center pivot. However there's no way to peen the kick so it doesn't look like you peened it, which most people would see as major damage.
I did that with a beater Camillus Army Engineer knife because the main blade settled too deep for the nail nick to be accessible. Peening worked, too, but the result was definitely ugly. It's a functional fix, and pretty much a last resort. I'd send the #73 back, telling them how it happened and being prepared to pay to have it fixed.
I have no GEC knives, but it sounds to me like the design could use a little tweaking so edge-crashes don't happen.
You should read the OP.
What Bob said. You obviously did not read the opening post. It was not an "edge crash".
The OP should stop doing what he has been doing, and send the knife back to GEC or sharpen away the chip himself to fix it.
To be fair, that is not a warranty issue. That can be done to many knives. It should "sharpen out" eventually.
