So I just ruined my second blade (1095) from trying to correct blade warp out of the HT. I snapped both in two. I've done quite a bit of research on correcting blade warp once you get it and I know what I did wrong on both occasions when trying to correct the problem (working it too cold).
What I'd rather do, however, is avoid blade warp altogether! I have two theories:
One, uneven blade grinding. I've only done two knives now so I'm still learning. This could definitely be the problem.
Or
Two, I'm using a homemade furnace that only heats the first 6-7 inches of the blade evenly. The OAL is around 8-9 inches. The handle doesn't get as hot so I'm wondering if this effects the blade and causes warp in the quench (brine). Is this a possibility?
Any thoughts?
I bought two aluminum plates to interrupt the quench at 450 degrees and then cool the rest of the way in the vise between the plates but I haven't tried it yet. Also, when I was practicing this cold, this technique would still allow my blade to warp some as only the handle gets firmly flattened. There is still a bit of play with the blade as it's been ground.
Help me please!
Or
Any thoughts?
Help me please!
