- Dec 21, 2006
So now I'm scared to death. Made my edge a little TOO thin on the Blue Steel chef's knife. There is an area about the size of a nickel along the edge that warped out maybe 1/16". What does one do here....or is there anything that CAN be done? I am very familiar and good at the 3 point clamping method for straightening bends along the length of a blade....but that isn't going to help here. I thought of doing something similar.....just using my C-clamp after one temper has been done, and clamp down on that one spot and temper again. The only problem that I can see there is usually a bend must be "over-corrected" to end up straight...and simply torquing down on this with a clamp will not "over-correct" it. I may try to come up with some sort of mini 3 point system...i dunno.
I am very frustrated and disappointed with myself right now. Tried to go as low as I could on that edge thickness, but alas it was too thin. What was it? I didn't mic it but it was getting close to .010". The spot affected was thinner than the rest of the edge by just a smidge....my grinding wasn't too perfect. The rest of the edge was about .015" and looks great. I try to get as close as I can to final edge thickness (with decarb to take into account). But I seriously need to start leaving more meat on the edge and deal with it after heat treat. Live and learn. Cussing and screaming falls in there somewhere, along with objects hurled at hyper velocity across the room.
Carbon steels should have at least .020" on the edge, dummy.
