Warping issue
Hi,
I have been making knives for about 4 years now. Just the past couple of months I have been having a real bad issue with warping. Not just in the quench but also during normalizing. I can actually watch the blade warp while its heating up in the forge. I will bring it out, hammer it straight, and put it back into the fire only to see it start warping again. This happens over and over again until I finally get tired of it and quench it anyway. I will usually hand straighten it to some extent right out of the quench and then clamp it to a file while its tempering. I haven't changed anything that I know of in the last couple months from what I have been using / doing in the past. I use mainly 1095 and damascus steels and heat treat with a propane forge. Any ideas as to what is going on?
Make sure you are heating the blade evenly.
Try raising the normalization temperature to 1650F.
Try a pre-quench after normalizing, then re-heat to 1600F, straighten, and re-heat to the austenitization temp (1475F for 1095).
Thanks for the tips. Pre quench in Parks 50 just like normal only put it back into the forge afterwards and then straighten?
