- Jun 4, 2010
Hello all, recently had to stop making these by hand and went to having the tops machined instead. Was able to to make some changes to the product that were previously not practical. More surface area, from 8"x2" to 2.625"x 11" and more positive means for drawing bonded abrasives tight to the board.
Versatile, simple, effective. "Clean Up Your Edge!"
Wet/Dry sandpaper not just for convex and scandi, does a great job on V bevel as well.
short video working on a CS bolo machete:
[video=youtube;ux-wH1i_2FQ]https://www.youtube.com/watch?v=ux-wH1i_2FQ[/video]
and overview of the new mounting scheme, also demo'd in the above video:
https://www.youtube.com/watch?v=TGcdZ_G570U
Was able to drop the price a bit per unit, but due to larger size the shipping is more. $60 delivered within US - $66 to Canada.
I can accept CC through the website, or check, PayPal, etc by directly contacting me via PM or email. Feel free to contact me with any questions or comments:
martinm@washboardsharpening.com
http://www.washboardsharpening.com/
CLEAN UP YOUR EDGE WITH THE WASHBOARD SHARPENING SYSTEM!
WHAT IT IS:
The Washboard is a heavily textured 2 5/8"x11"x1/4" acrylic plate bonded to a wood base. It sharpens and polishes using any abrasive that can be applied to a thin substrate. It can be used to sharpen and maintain a wide variety of cutting tools.
HOW IT WORKS:
An array of narrow ridges interrupted by thin relief cuts, dramatically increase the abrasive action of grease and wax based compounds to grind and polish. It manages a large improvement in plain paper for finish stropping/cleaning/tarnish removal as well. Multiple sheets of paper/thicker paper can be used to "soften" the surface when doing full convex or Scandi grinds if desired. Used with sandpaper or lapping film, it provides greater tactile feedback than a flat plate. By reducing the footprint, heat buildup is reduced, stock removal rates are increased, the surface of the bonded abrasive becomes less compliant. Longer life of the wet/dry sandpaper/lapping film is also possible through reduced glazing of the abrasives.
WHY USE IT:
Its versatile and easy.
The ridges and relief cuts work to increase the pressure exerted by abrasive particles without an increase in overall pressure, they also compress the paper and make it much more dense - the edge doesn't sink in, rounding the cutting edge as it might with a more compliant surface. Even with relatively heavy pressure the surface remains unyielding, yet burr formation is still mild compared to grinding on a fixed abrasive. Edges stay crisp and "catchy", even when stropped many times.
The ridges and relief cuts also provide much greater tactile and auditory feedback - one can tell if they are on the bevel, the shoulder, or if they are just beginning to ride the cutting edge (if one isn't at the proper angle it will feel like they're moving the cutting tool over a washboard. The amount of feedback increases as one gets further from the ideal or target angle.). This makes it a much nicer tool than many other choices when one is trying to quickly touch up an edge, or is doing a moderate amount of work restoring a worn edge. This characteristic can also be useful for maintaining angle control when working with sandpaper or lapping films.
Combined, the unyielding surface characteristics and increased feedback make the Washboard a lot more forgiving on the one hand (pressure), and helpful on the other (holding proper angle when tired, rushed, or inexperienced). End result is greater consistency for beginners and casual users, and greater versatility for more experienced users.
It can be used to polish larger areas and to maintain overall blade geometry during maintenance sharpening, touch up battered edges, do crisp work on V bevel, convex, Scandi etc, all with a minimum of steel loss, burr formation, and fuss. Best of all perhaps, its characteristics only change when you want them to - it is unaffected by loading, glazing, contamination, nicks in the surface.
Due to its light weight and flexibility, one can carry a complete sharpening setup that weighs only ounces yet has the feel and convenience of a full sized bench stone.
BEST PRACTICES:
It was designed to work with 20# Bond, 50# text, 75GSM copy paper - these are all different designations of the same basic copy paper. Lined writing paper found in most spiral notebooks is the same base weight as well. Using it with other papers or materials is possible and can yield good results, but care should be taken.
If the paper is somewhat thicker than spec'd, it can be pre-compressed by wrapping it around the Washboard, and rubbing it vigorously with a clean dry rag or paper towel using pressure. This is actually a good practice for all weight papers. Additional sheets of paper can be used if an even softer surface is desired, such as for Scandi grinds and full convex edges, or for general polishing.
Do not store or use the board with the working surface in direct contact with a stone or other hard surface - if the teeth become damaged or smoothed out, the Washboard will still work, but not as efficiently, and there is no way to repair it.
The Washboard can be used with a wide variety of abrasive compounds, simply make certain the compound is rated for steel or stainless steel, and understand if it is for heavy cleaning or final polishing. I recommend using a coarse emery compound followed by a finer stainless polish. Abrasives intended for polishing plastics or precious metals will not work well if at all. Also, the abrasive must not be water-based or the paper will disintegrate with very little use if not allowed to dry.
The Washboard excells when used with sandpapers and lapping films, simply secure around the board the appropriate grit paper and it becomes a full-service sharpening system. Make sure to use silicon carbide wet/dry sandpaper, available at most auto parts stores. Remove debris from the sandpaper with a large eraser, synthetic wine cork, or crepe rubber. For maintaining edges, paper with compound is all that should be required.
If the paper becomes damaged or loaded, simply recycle it.
