Washers Question?
Are the washers in a knife suppose to rotate in a knife as you open and close it?
Yea, I'd say most don't. I've seen some really cheap knives with spinning washers, but even those are rare.
Sent from my Nexus 6 using Tapatalk
Not supposed to.
The blade rotates pressed up against the washers, the washers shouldn't move.
It all depends on which surface has a higher coefficient of friction. Generally, the heel of the blade is more polished than the inside of the frame.
Dual washers, ideally, should only rub against each other.
I love questions like this because they make you think about the little details about that final fit and finish. Thanks for explaining it in basic science HDave
