chocomoco said:Do the Bronze washers inside your spyders ever wear out?
chocomoco said:Has anyone experimented with a different material to smooth the action?
Scott, wouldn't the smoothness of the blade tang be equally, or even more, important since it is the harder of the two? It's always been my understanding that mirror polishing the tang is the most effective way to increase both the smoothness of the action and the life of the washers.A second note, the more polished the washers, the smoother, and longer lasting, they will be.
A highly polished PB washer will last a LONG time, and be buttery smooth.
The Deacon said:Scott, wouldn't the smoothness of the blade tang be equally, or even more, important since it is the harder of the two? It's always been my understanding that mirror polishing the tang is the most effective way to increase both the smoothness of the action and the life of the washers.
chocomoco said:What grit do you go up to when polishing the tang -- 2000? 4000?
chocomoco said:The PB washers are so small and thin -- how do you polish them? or do you replace them with new/ higher tolerance ones?
chocomoco said:I'm going to open up my knife and do some experiments tonight...
