Water purification system for hunting/backpacking
I have found it's fun to filter my water with a bandana and then boil the water afterwards. But depending on how long you plan to be out, that can be a pain in the rear. The first two or three times is fun, building a fire, putting up the 'ole pot, and kicking back making water. If you are trying to get stuff done, then this method would be something to avoid.
The pumps mentioned above would be great and have proved themselves to be worthwhile in the field. Simple to use, almost last forever (I don't think two of you are going to drink 1000-2000+ gallons of water in a couple of days ;)).
You said you didn't want to use chemicals, I understand that part, but I've found it helps me feel a bit better if I pop in an iodine tablet into my Camelbak to ensure it's good to drink (and cleans out the inside of the pouch).
I had a Katadyn Hiker pro explode on me in the feild. we had to filter alot of murky water!
thank god I carry a steripen also.
I bought the frontier pro filter because it conects to my platypus bags and you can drink straight from it. it's only 20.00 also. I use the steripen as a backup plan, I am not into chem cleaning water either.
Connect to almost anything, using the universal connectivity system. The Frontier Pro filter will connect directly to any water bottle with a 28mm opening such as a Platypus® or standard spring water bottle. Using the tube connection feature you can connect to the drink tube of your hydration system, or drink from any open container or water source. Since you drink directly from the unit there is no chance of confusing inlet and outlet tubes resulting in possible cross contamination. The Frontier Pro can also be set up in a “gravity flow” mode to filter water unattended while you pursue more enjoyable uses of your valuable outdoor time.
SteriPEN® JourneyLCD Handheld Water Purifier (JY-RP). The revolutionary SteriPEN JourneyLCD uses universal symbols to take the guesswork out of the water purification process. Journey’s integrated LCD screen displays the user’s dose selection (1/2 liter or 1 liter), battery status and countdown timer. The LCD screen also tracks the number of uses and signals when lamp usage approaches its life limit. At 10,000 cycles, lamp life for SteriPEN JourneyLCD reaches a new high (purify 1 liter 4 times a day for nearly 7 years!). Like all SteriPENs, the Journey is Fast (48 seconds for 0.5 L (16 oz.)), Light (128g /4.5 oz.), Effective, and even easier with it’s innovative LCD screen. The Journey mates with the SteriPEN pre-filter and is sized between our Adventurer and Classic. Journey ships with two non-rechargeable (disposable) CR123 batteries. Suggested Retail Price $99.95.
One thing that I like about the Aquastar over the Steripen is that all you have to do is fill the nalgene-size bottle, turn the unit on, place it upside down in your water bottle holder/pack and start walking. 80 seconds later, it's done. It's a bit more of an enclosed process. However, both are good units for clear water.
DancesWithKnives
I use a Katadyn filter bottle. Good bang for the buck (kills viruses, too!).
I bought mine recently and only tried it out once on a hike. It might be just me, but the water tasted a little strange. Maybe it's the iodine in the filter, I don't know. I'll have to see if it becomes better with time.
I bought it because I wanted something reliable (no batteries), something that kills viruses and something that is easy to transport and to handle for a low price. It was the best compromise for my situation, because I have lots of clear streams around me. This bottle filter doesn't work with muddy water.
Though the streams I use look (and smell) clear/clean, almost all of them flow through farmland, so they're likely to be contaminated by cow dung.
