- Apr 9, 2004
Simple question, how long are they good for? There is no expiration date that I could find on the bottle.
Scott
Scott
>iodineHave you ever tried drinking water after popping one of those in it?
Sure... More times than I can count. Not the best taste but who cares. There is a time and place for filters and a time and place for tabs... They are great for back up also.
They have a new tab that is supposed to offset the iodine taste, never tried it.
Ski
I, personally would replenish tabs every year or so, just in case. The ones I bought said 5 years, but for the low cost, I would replace them every year. (Un-opened, sooner if opened)
>iodine
>chlorine
>chlorine dioxide
All taste different to me, but I really hate the iodine.
Regular chlorine and iodine are not reliable against giardia or cryptosporidium, and they are the most common biological hazards in North American wild water. That leaves chlorine dioxide and a wait of 4 hours; boiling; filter + chems; or radiation (e.g. Steripen) (with all the issues of electronics that don't like severe cold or being dropped). Of course, safer is better even if not perfect.
Nothing is 100% guaranteed to "purify" the water.
Tablets don't actually purify, they "sanitize" the water. It will kill most of the germs/bacterial but will not remove any chemicals or dirt.
UV radiation (ie Steripen) will kill most if not all the bacteria/germs, but also won't get rid of the chemicals or dirt. IMO best if you are fairly certain the water is chemical free.
A good Filter will get rid of most (99%+) germs/bacteria and probably most of the chemicals, and most if not all the dirt. But it won't be 100% against the germs/bacteria. IMO this is the safest all around for clean water.
Boiling will kill most if not all the germs/bacteria but no removal of chems or dirt.
What to do? To be a bit closer to 100% do tablet or UV or boiling AND filter. In my humblest opinion I think the tablets are the least reliable.
IMO if you are going to do only one use a filter. Unless you are fairly certain the water does not have any chemical contaminants (Hey, I'm from lower NY, lots of chemicals floating around here!)![]()
The Aquatabs I buy have a shelf life of 5 years. They state the manufactured date and the expiry date clearly on every little packet.
While tablets will remove harmful viruses/bacteria, I use a bandanna around the opening and this usually gets all the larger stuff.
Sawyer sells a filter approved by EPA to remove even viruses. Works by gravity and is back-flushable. Not sure how well it works in the field.
I notice no taste in the Katadyn Micro Pur tabs unless the water I have collected is very clean, then there is a slight medicine like taste. I figure they had nothing to do. That being said, there will be variability in where and even how the water is collected. This is what I do...
Do you know anything more on this? I remember seeing a filter "straw" not too long ago. Remember it could do 20 gallons of water. I think it was fairly cheap too. Ran around $20.
Sawyer® Virus Micro-Filtration Water Filter
The Sawyer Biological Filter removes 7 log (99.99999%) of all bacteria like salmonella, cholera, and E. coli. And 6 log (99.9999%) of all Protozoa such as Giardia and Cryptosporidium. You will find these removal rates to equal or exceed competitive options. Therefore Sawyer offers the highest level of filtration available.
The Sawyer Water Purifier offers the same level of protection against bacteria and protozoa and is the first (and thus far only) portable filtration device to remove viruses mechanically. It does so at a 5.5 log (99.9997%) rate, exceeding EPA and NSF recommendations.
With no pumping and no chemicals required, this system delivers 4 liters of purified drinking water in as little as 15 minutes.
* Features a 0.02-micron hollow fiber membrane purifier that physically removes particles, protozoa, bacteria and viruses while maintaining a high rate of flow.
