Edited to elaborate a little.
marsupial said:
Rationing water is pointless as its better stored inside you rather than in your canteen.
Your body always attempts to maintain homeostasis. When the amount of water in your system exceeds your needs, it is excreted in urine. Gorging yourself on limited water supplies is reckless at best and deadly at worst. You'll piss it all out the first couple days, and then you're out of water.
Gorging yourself really only applies when your canteens are running low while travelling and you come upon a good water supply.
It also has to be elaborated that drinking a lot of water will make a case of dehydration WORSE, not better. You also need electrolytes for water reabsorbtion by the kidneys, and you need some glucose for uptake of electrolytes. Drinking more water will just wash out even more of your limited electrolytes, causing more water to be lost, and so on.
You also don't want to use something like Gatorade for rehydration, as it's much too high in carbohydrate (which slows gastric emptying and in cases of vomiting/diarrhea may exacerbate fluid loss) and too low in sodium, potassium, and base. Gatorade is fine for sweat replacement in a healthy individual, provided dehydration has not yet taken place.
Pedialyte (or a similar product) is much better than sports drinks for rehydration.
In cases of dehydration where Pedialyte is unavailable, the CDC recommends the following oral replacement cocktail, prepared in two separate glasses.
Glass 1:
8 ounces fruit juice (orange, apple, etc,) that is rich in potassium
1/2 teaspoon honey or corn syrup (glucose necessary for absorbtion of essential salts)
1 pinch table salt
Glass 2:
8 ounces water (carbonated or adequately purified (not an issue here))
1/4 teaspoon baking soda (sodium bicarbonate)
Drink alternately from each glass, supplementing with water or tea as desired. Avoid solid foods and milk until recovered (that part mostly applies to cases of vomiting/diarrhea)
If you don't have all those ingredients available, you can also use the Poor Man's rehydration drink, which is a can of ginger ale diluted 1:1 with water, and a pinch each of sugar and salt.
