Do take care if you shop for the Benchmade. As the above link points out, the company "upgraded" that knife from X15 to H1 steel a couple of years back. Some vendors still have the X15 in the pipeline, and I prefer the H1 steel if Spyderco's H1 knives are any indicator of how the upgraded Benchmade knife will perform.
The above post is wrong
I glanced at the Benchmade info too quickly and had my timeline bass ackwards. Benchmade USED to make the knife in H1 and then switch over to X15 T.N sometime around 2005. They changed the knife steel info in their 2006 catalog. I ordered from a vendor who advertised an H1 blade (part of the reason for my confusion above), but since he'd only had the knife in stock for about 9 months, my guess is that it's really X15 T.N--a French steel used in the aircraft industry. The vendor looked at the knife for me, but could see no way to tell what steel is in it.
hikeeba, if you've had yours for four years, then you definitely have the H1 version.
I called Benchmade to see if there's a way to tell the difference. First person in customer service swore up and down they stamp all their blades. I already knew this wasn't true after talking to the vendor about my knife and after reading a few threads online. They don't stamp this model so that corrosion won't have any small pits in which it can set in. Anyway, a more knowledgeable person in Warranty and Repair said that the only way to know which steel I'm getting is to send in the knife and have it tested by Benchmade.
Here in TN, I'm not going to be around salt water, so I imagine either steel will be fine. I do plan to disassemble the knife, give it a good coat of Marine Tuff Glide (under the scales and on the hardware), and put it all back together. Just to be on the safe side.
On another note, I asked Benchmade if any of these knives had been coated at some point. I was told that they weren't. However, in shopping for the knife, I saw what I thought at first to be two different models. Does anyone know why these pictures depict knives that look so different?
One poster at the Benchmade forum noted to me that the H2O has been discontinued this year. That means two things: (1) you might be able to pick it up on closeout somewhere on down the road... maybe... (2) you might find it harder to get this knife pretty soon. Just a heads up.
My call to Benchmade made this info out to be rumor. According to the lady in Warranty and Repair, the model is not being discontinued.
Gunyon,
While the River Shorty is a decent and popular river knife, the factory sheath has been notorious for losing knives. I've been making retro-sheaths for it since I first started making sheaths.
Thanks Mike. I've also read the factory sheath
can be tough to attach, depending on your PFD. I may bend up some kydex and use a small Tek-Lok on it.
