Water - Vital for survival.
I find myself debating whether to try and add a plastic bag to my smallest kit for the purpose of collecting water by condensation or for a solar still. The problem being that the plastic uses up valuable space and is difficult to constrict to a very small package (depending upon the thickness). Is there a survival product designed for this purpose or has anyone worked out how to beat the challenge?
The baby bottle liners are more easily rigged for those uses and others. And resealable.
Phil
Before you go to alot of trouble putting togeather materials for a solar still, you may be interested to check out the myths of the solar still.Click Here
Neal
Thanks for the link, Neal. Like many, I thought solar stills were an efficient way to collect water. You have done a potentially lifesaving service by posting this here.
The best use for the solar still is as the end game in your water collection strategy. If you have already searched for water by going downhill, looking for seeps, etc and you haven't had any luck then you will have to find a place where surface water is reachable by digging. Find a low moist spot and dig. If you have dug through moist soil and have a fair sized pit already and water dosen't pool in the bottom, then and only then would a solar still make sense.
You should go out and build one, a big one, on a camping trip sometime. Make sure you have a wide mouth receptacle in the bottom and steep sides to the plastic so the water runs. Record the amount of water you drink making the thing and the quantity of water produced. They are a huge disappointment.
Transpiration bags work if they are large and clear. The bigger the better. Check limbs for bugs and bird droppings. The bags have to be sealed tight and left for a long time. You will still need to treat the water in most cases. If you use enough bags on enough of the right kind of trees you can produce water. In my experience this will produce as much if not more than a solar still with only a fraction of the work. Mac
Thanks for the info so far. Do we carry a BIG plastic bag in our kits, if so has anyone added one to their kit? What and how?
