People say if you use oil on a sharpening stone you will always need to from then on, is it the same with water? I have a norton 2 sided india stone and wanted to see what kind of results I can get using water. Will I always need to after this?
Ah-ha! I should have known that a waterstone guru such as yourself would have knowledge of such things.DoW,
Adding baking soda to water reduces that rusting-before-your-eyes from happening.
No, because the water will evaporate, leaving no residue (unless your water has a lot of minerals in it). Once it is dry, you have the choice of using water, oil, or nothing at all. Once you use oil, the stone is contaminated with oil, which is difficult to remove every trace of.
I think oil does evaporate, it just takes a long time. I think.
I like soapy water, it seems to reduced the rusting factor and breaks the surface tension seemingly to increase the feed back from the stone. Not sure how well it works on other stones but works excellent on diamond stones.
ISoap is better than dish detergent because dish detergent is more corrosive to metals.
I used to believe that was true, but not so sure anymore. For one thing I think many who are using water, or soap & water, Windex, etc. on stones are starting with stones that are oil-soaked from the manufacturer -- e.g. just about every bench stone Norton makes except the cheapies. Plus water (not talking soapy water here) and oil shouldn't react, except perhaps to create a milky-looking mixture, and the water should evaporate out afterwards. This leads me to think there's more going on.Using water on an oiled stone just doesn't work well. Most often it's because the steel particles, water, and oil turn into a gummy paste that loads the stone surface, and you can't just add oil or water to flush it off. If it's left like that without a thorough degreasing and cleaning it will glaze the stone surface, which is really just a pain the ass to deal with.
I have all but ruined medium SiC stones doing this in the past, as well as fine AO stones for which there's really no recovery.
I'm astounded people have the patience for oil stones. Waterstones are way quicker.
