jdm61
itinerant metal pounder
- Aug 12, 2005
Most of the coarse grit belts that I have used over the past 10 years have been suitable for wet grinding. Finer grit belts? Not so much. As I am grinding thin stuff more and also grinding heat treated steel like AEB-L and CPM 3V, I would like to be able to use my Nathan platen chiller and also an "IV drip" type cooling system as much as possible so that i don't have to spend so much time with EDM stones chasing bigger scratches. What belts have you guys used in the 600 or even 800 grit range that are waterproof and have a slightly stiffer backing compared to the super flexy ones that you use for finer work handles, guards, etc?
