Waterproof Matches Test
I found a couple boxes of these "waterproof" safety matches while going through one of my old packs this morning. I guess I never used them while camping and I always just assumed they wouldn't work that well when wet, compared to my mag/ferro stick. Well, I was right - sort of.
So I figured I'd try them out at home, where my life or comfort wouldn't depend on them working:
First, I tried a couple from each box (2 different manufacturers) to make sure they lit up fine when dry. Took about 2 strikes on the side of the box for them to fire up.
Next, I dipped each one in a cup of water and tried to light them up. Again, it took about 2 to 3 strikes but they still went up, no problem.
Then, I put the head of each one under running water in the sink for a minute. This time there was some minor crumbling of the matchhead when I tried to light but they all still went up after 2 to 3 light strikes.
Last, I left a few floating in a cup of water for just over an hour and then tried to light. Unfortunately, the matchheads all had gotten soggy and either crumbled or smeared and none of them could be lit.
So, calling these matches "waterproof" isn't exactly false advertising. They did resist a little wetness and would probably work fine outdoors if only temporarily wet or submerged. I also found that, when wet, light pressure worked best (to avoid the head crumbling) whereas more pressure lit the match faster when they were completely dry. Not exactly scientific, I should've had a control group (some regular "strike anywhere" wooden matchsticks maybe?) but a fun and "illuminating" experiment nonetheless.
This is a good reminder to test your gear. I have had a box of these in my bag for a couple of years now. I guess I need to try a few out to make sure they are still good. Of course I also have a bic lighter in there too, but I should probably try that out as well.
I've been doing stuff like this lately with several aspects of gear, it's always interesting (and valuable) to see where the limits are. :thumbup:
i wonder if the matches got soaked because the wood is not coverd in wax like the heads, which would allow the water to get under the wax coated head...you might want to try the hurricane wind and waterproof (nato) matches for a good comparison and a better replacement for your pack.
I wouldn't only take these kind of matches, if I were to take only matches (Never). I had tried to start a fire with these before, but they wouldn't start when I dropped in in some wet snow.
I read an article today in Field and Stream that said to dip the matches in clear nail polish instead of wax to waterproof them. I actually have some drying right now. Hope they work!
abiggs- report back. Im curious to what you find!!
The clear nail polish works like a charm. I only held the match under water for a few seconds, but I took it out and dried it off and it lit right up for me.
1 - Dip just the head in the polish, wait for it to dry
2 - Dip again, but go about halfway up the match, wait for it to dry
Walla, waterproof matches!
This is one of those times when the wife walks in, gives you that look, shakes her head, and walks out of the room without saying a word.
Do you have a spy camera in my house??!! :D
She's pretty used to me spending most of me free time doig things related to knives, camping, outdoors, etc. She thinks its pretty silly, but luckily she usually humors me and leaves me alone!
