David Martin
Moderator
- Apr 7, 2008
12C27mod is the same Sandvik steel that Buck uses. DM
Opinel too. It's pretty good stuff! :thumbup:
i've yet to buy a stainless opinel or a buck in 12c27, but it's a fairly common steel in mid range traditional french and european cutlery, typically HT'd to 56 hrc average. and in this hardness range i can tell you that it sucks big big time. at least in my opinion. it's soft enough to be a pain in the .... to get a clean, wire free edge and you can forget sub 20°(per side) edge you just won't get rid of that wire edge, no matter coarse, polished stropped, slicing in hardwood, feather light pressure while sharpening ... no way.
HH is referring to waterstones at 1200 grit, which is relatively coarse under that completely different standard. DMT's '1200' won't match up with another standard's '1200'. Maybe not even a close match, either by grit type, size or cutting performance. I think a comparable waterstone, in terms of refinement/polishing performance, would be at a rated grit number quite higher.
A 1k waterstone is closer to 15+ microns, like 400 grit wet dry, a mix between a coarse and fine diamond, and with the speed of a 600 mesh fine diamond hone.
A DMT EF 1200 mesh 9 micron hone has a scratch pattern like a 3-4k waterstone and similar level of sharpness. Edge roughness is in more around 1k waterstone though.
A 1k waterstone should clean shave arm hair and slice paper without catching. This is only edge trailing though, if I go edge leading I end up with a edge that won't even grab a hair or slice paper but oddly enough looks fine.
I'll see if I can get some pics off my 1k, I have yet to view that edge type up close so it will be interesting.
What steel was used for the waterstone pics?
