Wave feature easy to use?
I'm thinking about picking up an emerson with the wave feature. Just wanted some input from the guys that have folders with the wave. Is the wave opening easy to use?
I've seen lots of youtube videos and such showing it work but wanted some honest input about its real utility.
Thanks.
It takes some practice, but becomes natural after a while. For the smaller waves, I found it works better if you pull out and not just back or forward.
It works very well, maybe too well (I have had a few inadvertent, unintended wave openings). Be advised, though, that training is needed, and I'd strongly recommend using a trainer for that. The Spyderco wave D4 and E4 trainers are, I believe, discontinued, and available at very attractive prices. They'd let you get the hang of it safely.
I prefer using the thumb wheel, my son on the other hand uses the wave like its second nature. Identical knives, mini cqc-7b. I do enjoy the feature, though. More than anything, like JN said, inadvertent and unintended openings do occur upon removing from pocket, etc...Important to be aware of this. I would recommend.
The wave opener is easier to use on some models and has more of a learning curve on other Emerson models. I would have to say the folding karambits are the easiest for me to deploy......but the end ring just makes it a simpler move towards opening.
I don't see Mr. Emerson using the wave on nearly every EKI knife because it dosn't work. :p
It's real easy to get the hang off, I find giving the knife a bit of a twist as you deploy it helps the pocket grab the wave. That gives a good solid deploy pretty much every time.
If you do want to take the knife out your pocket with out the wave opening it (like when your taking the knife out your pocket before bed etc.) You just have to wrap you thumb round the top of the knife or pinch it with your thumb and index finger to stop the blade opening. :):thumbup:
I personally am not a huge fan of the wave TBH and have removed it on a few of my users. That said it does work and is actually great if you use a deploy sheath.
does the wave work well with IWB carry?
My own experience is that it doesn't work well with IWB. Even some pockets don't work well. Others may be more talented with this than I am, though...
Works best on jeans.
Now you know why I wave almost every folder I get.
The first time I put a waved Emerson in my pocket I pulled it back out and it opened;)
They have been doing the same for me ever since:thumbup:
I never wear dress pants though so maybe that is the problem for some folks?
Do not hesitate to purchase a waved Emerson in my opinion:)
I've had it happen with a jeans-type shirt pocket. :eek: Works great, even when not expected! :D
Yes, the wave feature works as advertised.
Just be careful the first couple attempts that you don't acquire the same little nick of the finger I received my first time pulling a CQC15 from my pocket. Emerson's are razor-sharp out of the box and don't suffer oafish behavior!
I EDC the 15 in a gunmate belt pouch positioned horizontally on my left side for cross draw deployment. It appears suddenly with an impressive "SNAP".
I can easily slip it out silently unopened in less knife-friendly groups, but damn, I love the looks I get when I let the knife do its thing.
Agreed. It's almost impossible to wave out of suit pants or other pants with slanted pockets. The wave hook needs a firm corner to function properly, so any fairly sturdy jeans or chinos with "jean-style" horizontal pockets will work well. Some chinos and cargo pants have slanted "dress-style" pockets, so if you intend to wave as your primary opening method, you might want to consider what kind of clothing you usually wear.
Waving from your strong-side front pocket is stupidly easy, and it takes only minutes to master. It's never a bad idea to start with a trainer, but I never bothered- it really was just that simple. Grab the handle scales firmly, tug sharply up and to the rear, and the blade slams out with a very confident sssssnick! Some people also like to twist the handle slightly clockwise, and this may make it easier to wave out of pockets with more difficult shapes. Honestly, though, I cannot say enough good things about the wave. It is absolutely the fastest opening system available on any knife in the world- the blade is open exactly the moment it leaves your pocket. You will have an open blade and a ready knife before I've even touched the firing button on, say, my Auto SERE or Troodon.
Some people can even wave out of their strong-side back pocket, depending on how it's clipped in. That takes a little more practice, but it can be done. The wave's only weakness is that it must be deployed out of a pocket. I've seen people come up with creative ways to wave; the most curious method involves using the fly of your jeans to catch the wave hook. I'm not sure I'd ever want the very pointy tip of my Mini 7B coming anywhere near my bedroom equipment, though. You cannot wave IWB, you cannot wave off a belt, and you probably will not be able to wave out of a pouch unless you use one of EKI's wave-feature holsters. In those instances, you'll have to fall back to the thumb disc, which is reliable and easy but quite a bit slower.
Regardless of how you open, you might be tempted to back out the pivot screw a little to let your blade open faster. Some say that's just a matter of taste, but I'll say do not do it. You're sacrificing a lot of lockup strength and blade stability for what is, in the long run, only a small amount of additional speed. Tighten down the pivot screw as much as you can, so long as you can still thumb the blade out smoothly and easily. This is not a lockback or an Axis- don't expect the blade to flick out super fast. This is an Emerson, not a Benchmade, and you'll start to love it for what it is as you use it.
Final word on waving: while Ernie Emerson heartily allows waving and thumb/wrist-flicking to your heart's content, keep in mind that this will cause accelerated wear on your stop pin and lock bar contact face. That may be important to you or it may not, since EKI are always happy to freshen up your knife for a small fee if you send it in. Just something to keep in mind.
[youtube]DAA_rOVgwc0[/youtube]
Here's an example of rear and forward wave draws.
Nice vid, Matt. I thought I waved fast, but not now. Thanks.
-Tye
Thanks! I only carry waved knives and drill from different positions. I like to keep a knife of some sort that I can reach in almost any position.
