- Mar 3, 2007
I just got The EFC and the wave behaves differntly depening on your pants. I like no brainer consistency, especially in hostile circumstances. So The wave gets a no from me, my humble 2 cents.
That third knife is my pocket hook. If you imagine a flat L shaped piece of steel that has exaggerated length to make bending them easier, well thats how it starts out. What I used is titanium which you have to heat to cherry red to make each bend. Its a lot of work to make one of those. I then bend it down so it would fold at a 90degree angle and then drilled a hole in it with a #44 drill bit. This is the proper size fora 2-56 screw which is the size screw in most thumb studs including the one in that picture. I first check it to see that it fits and that the hole is in the right place. Remove the thumb stud and screw it down again with longer screw and tightent. Then mark my line where I will make the bend to make the Wave hook that will catch the pocket. I then make that bend and with some finesse and fine tuning after sanding with some drum sanders its a bead blasted and placed on permanently.
You don't need anyones permission to do anything to your own knife no matter what anyone tells you. Believe me I know. I sought legal counsel before doing these and even after being told I could make them for myself I wanted to clear it with the holders of the intellectual property.
When forum members started writing me to do them for them is when it changed. Once again I wrote Ernie Emerson and called Andy Demko and got their permission to copy and use their IP. Nothing wrong with being up front and letting them in on what is happening when its for yourself but its really a waste of their time to make them come to the phone or reply to it if its just for you. Both were more than happy to say have at it in my case because technically to do them for others and charge for it you do need permission. For yourself you don't.
STR
The wave is cool and works great but, I wish it was an option rather than being on all knives.
on my 14 it's more of a pain since I don't want the blade deployed EVERYTIME I pull it out.
I usually have to slide it forward in my pocket before pulling it out. I don't like having to concentrate on pulling on pulling different knives out in different ways.
Me, I like my EKIs without -- which is why I stick to the original non-waved CQC-8.
Now... as for the Wave.
I'm surprised no one has mentioned the Spyderco/Emerson collaboration P'kal folder, which has a...
...wait for it...
removable, optional, Wave.
-j
I asked Emerson a few weeks ago about "non wave" knives and they said they don´t really make them anymore except for customs. Sure there are some available here and there but if you want a newer one lets say a HD-7 it´s not possible so the choice is limited. Btw I edc both waved and non waved folders anyway.
Shouldn´t have to imho. Maybe E-n reads and take notice...why couldnt ya simply get a dremel tool and grind it off??
