Jason B.
- Jun 13, 2007
That shiny "white line" is the burr. That's what it looks like under bright light. When inspecting the edge you must turn the knife (twisting from the handle) and watch for any reflections or bumps at the apex of the edge. If the edge has no burr it will look almost dark and have a distinct bite into your finger. Grit really doesn't matter but as the edge becomes finer so will the feel of bite in your finger. The "bite" I refer to is when you lay your thumb on the edge and lightly press and pull your finger to the side. (Obviously your feeling a sharp object here so your touch should be feather light)
As soon as the finger is moved the edge should bite into the skin, just remember as the grit of finish increases the bite becomes more instant and upon contact. If the edge does not bite then you still have more work to do.
Did you use push or draw strokes for the micro?
Try putting the Chromium oxide on a piece of hardwood or MDF and doing the micro with that after the 1k. A ceramic rod or a UF SM rod would be much better though.
