<snip>... I think it would be better described by the maker as a short-term lubricant, with recommendation that it be re-applied on a regular basis. ...<snip>
I use it as a solvent. Years ago I spayed it on my tire lugs when rotating my tires. Short story is 6 months later when I rotated again I sheared of several lugs, I started using white lithium grease afterwards.
You likely sheared the lugs off because you left WD-40 on your lugs and/or lug nuts before reinstallation. Nearly all vehicle torque specs are dry torque specs. A lubricant, even water, will make it very easy to overtorque the fastener past its yield strength and caused them to shear.
DO NOT LUBRICATE YOUR LUGS.
According to the Curandera believers WD40 is a bursitis cure..Spray a little bit on the affected area rub it in, and your good to go....:thumbupr is it windex Hmmmm?
As a gunsmith and cutler, I have never found WD 40 to gum anything.
Even if it did gum up, why wouldn't more WD 40 dissolve the gumming?
WD-40 is a lubricant. The problem is it dries up very quickly, and removes any other lube on the metal, leaving the metal unprotected. Once dried up,Im glad there is someone else in the world that knows what wd40 is for. Its not a lubricant.
