- Apr 11, 2018
The STIXX features a 3.45" Bohler M390 stainless steel blade with a flat grind. You could use the thumb slot opening method or the flipper, which highlights WE's incredible action. The ergonomic handle is 6Al4V titanium with a carbon fiber inlay on each side with Mikkel's trademark oversized hardware and flow-through construction
$170.00
A+ ConditionShipping Included
CONUS only
Specifications
- Blade Length: 3.45" (88 mm)
- Closed Length: 4.55" (115 mm)
- Overall Length: 8.0" (203 mm)
- Blade Material: Bohler M390 Stainless Steel
- Blade Thickness: 0.16" (4 mm)
- Blade Hardness: 59-61HRC
- Blade Style: Drop Point
- Blade Grind: Flat
- Blade Finish: Satin
- Handle Material: Bronze 6Al4V Titanium with Carbon Fiber Inlays
- Handle Thickness: 0.70" (17.8 mm)
- Locking Mechanism: Frame Lock
- Pivot Assembly: Ceramic Bearings
- Pocket Clip: Titanium (Tip-Up, Right Carry)
- Weight: 4.66 oz. (132 g)
- Designer: Mikkel Willumsen
