- May 25, 2007
I like my Springfield Armory XD9 4"; It is compact ,lightweight and very easy to use weak hand or not & it works great left or right handed.
Glocks have a slide lock, people use them as a release, but that wasn't teh designer's intent. Simply find a sharp corner and press on the slide which will release the slide lock, then the slide will go into battery chambering a round. Weak hand only I'll stick with a 9mm, G17 or G19.I was originally ready to say "Glock" due to the simplicity of operation, but then I thought about the slide release being for right-handers. If someone made an ambidextrous slide release for Glocks (and I don't recall seeing one), that would be my pick... probably in 9mm for the advantage of low recoil for the "weak" hand. The model (size) would be based on your desired degree of concealment; same with the holster.
Otherwise, I'd probably pick a CZ-75 Combat model (it has ambi controls), also in 9mm. It offers single and double action operation, high capacity and cocked-and-locked carry.
Stay sharp,
desmobob
First of all, 1whitefoot, what knife is that in the top photo. It calls out to me....(and says dirty things in my ear)![]()
...I still think that a revolver is a poor choice. Low capacity and the long, hard trigger pull knock it out of the running for me, before we even get to the reload issue.
I would want high capacity, as I just don't think there's any way I could be as accurate weak hand only as I am two-handed. This means a semi-auto...
Interesting comments.
I intended this to be a "what gun for weak hand only for when you KNOW you'll only have your weak hand available," not if your strong hand gets hit in the middle of the fight.
For example, you broke your strong side arm/wrist, etc, last week and you have the option to plan accordingly with a gun that might better suit a weak hand only situation.
Sorry about that, I did not realize that you were only going after semi-auto's.
Thanks for clarifying.
In such a case, I'd still have to go with a small revolver in DA.
An FTE with a semi-auto due to limp-wristing with the weak hand will be no less detrimental to an SD situation than a limited round count in a revolver.
just my 02¢
I'm really not........but they DO make more sense (to me, anyway) than a revolver for weak hand only.
Do you disagree ?
I disagree, for sure. I have no trouble at all with even my heavy gp100, which is not a light trigger.
I don't find reloading much slower with a revolver and speed loaders than with mags.
Our weak (secondary is the term I use) hand drills consist of a discussion on gear. we begin by discussing the advantages of using gear that allows you to access your tools with either hand.
We then run through how to transfer the firearms from the primary hand to the secondary hand safely. Lay secondary palm flat, set gun in hand etc...
I believe the secondary hand stuff is good for several reasons, it gets people to question their gear, starts to develop some additional dexterity, gets people thinking about dealing with adversity.
I'm seriously left handed and would more than likely shoot myself with any gun pulled with my right hand. my second (gun) is a .45/410 Bond Arms derringer that I carry on my ankle....
