Also a heavy duty extension cord is a temporary and still dangerous solution, people forget about cords, they don't inspect them frequently enough the insulation gets cracked, the ends get stretched, strain reliefs fail and before ya know it fire.
Extension cords should never take the place of proper wiring.
I found a rather long heavy-duty extension cord. Not sure how long, but I've got two extra 25 ft'ers so I should be able to run from a circuit in the house, but I'm not even sure how great the wiring in there is as we just had a 30 amp T fuse and a 60 amp cartridge fuse blow last night.
It's only going to get worse. When copper is hot it oxidizes, which increases the resistance, which makes it get hotter, which makes it oxidize more ...
I'm going to try to get ahold of an electrician. What's just a ball-park figure of what I should expect to pay for this kind of service? Hundreds? Thousands? I really have no idea how much money to start with, and not a whole lot to work with. Is it possible for a company to give me a quote without seeing the actual wiring?
Anyway. Power goes off tonight, electrician gets called in the morning. Thanks, guys. Wish me luck.
I knew what you meant by "blowing the fuse"...
... the fuse acted to stop current flow in order to prevent a fire, the same as tripping a breaker in more modern wiring. 60 amps is a lot of current. ... The point I am drifting toward is that generally, nothing but a dead short circuit will blow a 60 amp fuse. Something is seriously wrong with the wiring in that house, and it will start a fire if it isn't repaired.
Ditto. It is really next to impossible to get a fuse to literally blow up in household electrical wiring. This isn't surprising. They're designed not to "blow up" but to "blow" safely with the outter body of the fuse safely containing the entire event. But, know this: that fuse interrupted a current well in excess of 60A, which, at 120VAC, is 7200W. That is a huge amount of energy.
Exactly correct.
Just to give one more point of reference, hand-held arc welding it typically done with about 100A, but at about 60V. At 60V, 100A is 6000W. So, that 60A fuse interrupted significantly more power than is used for typical arc welding. You have probably seen someone arc welding, the special mask they wear, the heavy gloves and apron they wear, the heavy cables used -- much heavier than even a "heavy-duty" extension cord -- the sparks flying everywhere, the big pieces of solid metal glowing yellow/white-hot and melting and flowing and fusing... that's 6000W. Imagine that... and a couple of thousand watts more worth... happening inside of a wall and with none of the protections that welders use.
Know this: When that 60A fuse blew, this is exactly what that fuse interrupted.
And that is why so many of your friends here are seriously afraid for your life.
Should I be worried by the fact that the fuse says 250 volt on it then?
I had a friend of mine look at it today. He's not really an electrician at all, but he's an older handyman type, and he pointed out a few problems to me. For one thing, the circuit that the 60 A fuse was on apparently has way too many things running on it according to him, and based on the amount of leads going into it. He also helped me spot that the wire leading to the garage is actually exposed on the outside of the house--no wonder I'm having problems with it. Anyway, he also made mention of the fact that we don't even know how old the 60 A fuse that was in there was, and that the one we replaced it with has been fine... So I'm not sure what to think about that. Obviously there is a problem, and it is still a fire hazard, but is it really on the verge of bursting into flames if it hasn't thrown this fuse too?
One thing I noticed today was that the other cartridge fuse in the housing for the range was only a 40 A. Do you think someone put a 60 A fuse in there because it kept blowing out the 40? I kind of think I should probably put a 40 back in just to be safe.
