- Jun 11, 2006
I'm not much for water or brine quenching as most of the steels I use are the deep hardening type. But I have been playing with some steel I have that is a medium carbon steel (guessing). I can quench in heated AAA and comes out hard but has a weird skin on it when I brake it. It's like the skin is not hard but the center is, I can file a good amount on the edge and then it hits the hard core and skates. I did a water and brine test in a shallow dish on a small chunk. Hardened like glass and no skin so I thought hum let's make a test blade. I have made other test blades and oil quenched them and thy came out nice and straight (long fillet knives). So I thought it would be time to try this steel in a brine quench. I grabbed my water tank which is a 2.25-2.5 diamater tube that's waste high with a round disk welded onto the bottom. I use it for quenching tongs and cooling blades when grinding. It's easy to hall around the shop holds a good amount of water and it's stainless. So I thought it would be perfect for a blade. I dump out the water and put in some salt and fill it back up. Set next to the forge and heat up the blade. Once heated in one smooth stroke I pull and quench. I was greeted with what I can onley describe as a harmonic explosion. The tube rang and very quick zip. The water surface bounced like there was a speaker under it. I pulled out the blade and it was slightly warped but rock hard. So I heated and straightened it and thought I will do just a quick quench. Will go in and out as fast as I can. So heated back up and one smooth stroke I pulled and tryied to quickly plunge and retract the blades in less then a sec. Well I plunged it and the same thing (harmonic explosion) pulled it fast once I hit full quench depth. Blade comes out slightly steaming, was only in the water like a half sec. All color gone and not very hot. What is happening? I'm guessing the tube is vibrating and disrupting the quench. But that's just a guess. Next time I'm out I will try and record it.
