- Jan 2, 2010
So I finally got around to finishing my EERF grinder, just got my gas tank back from my buddy, set up my welder and went to task.
I used clamps and some welding magnets to hold the base and upright in 90 degrees. I laid my first approx 1.5" weld....... Looking good. I take my normal break when welding at the high setting and start on the second weld (same side). I lay that one and forget to check the alignment to see if they are stil 90 degees to each other. I lay the third one and start feeling pretty good about my newfound welding prowess. Wait.... why is it leaning......OH CRAP!
So, where do i go from here. I have a slight lean to the upright that will be a pain to bend back. Am I stuck with cutting out the weld with an angle grinder and rewelding? I don't have an O/A torch so heating and bending back wouldn't be a option. It looks like when I welded on just the one side it sucked it down towards that side so would just welding the other side draw it down to that side and even it out?
I am so mad at myself right now. Any advice would be helpful and appreciated. The lean is what I would consider unacceptable and noticeable. I can take pictures if it would help out any. I just want to be up and grinding on this thing asap.
Thanks,
Nathan
Thanks,
Nathan
