General rule of thumb is one amp per thou of thickness, less for an outside corner joint, more for an inside corner. Thin material is much less forgiving than thick so be mindful how much heat you’re putting into the joint. Once you get it a little too hot it will melt the steel back and surface tension will cause it to pull away leaving a hole that can be tricky to fill. Practice on scrap first.
