Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
I regularly tell people to "Roughly" double the grits. If the sanding was done properly, that would be fine. I would say that 320 to 600 will work OK if you spend enough time on both steps. You should expect to spend ten to fifteen minutes on each of the first four grits, and five to ten in each finer grit in a normal steel for a 3-4" blade ( some steels can be triple this or more). It should take about two hours minimum, often a lot more.
I always advise to start with 120, then 220, then 400. After HT go back to 120 and start again, and roughly double the grits from there, 120,220,400,800,1000,1500,2000,2500. Whatever grits are available to you will be the ones you use. Your 120.220,320,600,1000,.... should be fine. Adding a 400 step certainly wouldn't hurt, as I find 400 is the point where bigger scratches disappear and from there it is just refinement of the finish.
One big thing to attend to is cleanliness between grits. You don't just change the sandpaper - change everything that will touch the blade. Toss the paper towels you are wiping with, fold the towel you are sanding on to a clean spot ( or change it), dump and rinse the water bowl, rinse off the sanding blocks, and WASH YOUR HANDS WELL. Then start with fresh paper towels, water, work surface, etc. One stray grit from the 220 can come back at 1000 to haunt you and make you say curse words you didn't know you knew. I would often guess that this is the source of a scratch that mysteriously appears after the blade is at a high grit.[/COLOR
Where your biggest error probably came ,was in not stopping between the grits occasionally and letting your eyes and hands take a break. I believe most everyone will find scratches they missed when they take a break of at least an hour and then come back and closely examine the blade.
Good cross lighting is also a requirement. The light needs to come from both above you and in front of you. A two or four bulb fluorescent overhead light and a good desk lamp will work well. If possible, use daylight spectrum bulbs. Soft/cool white bulbs make your sweeties face look pretty, but can make tiny details like a scratch harder to see. A desk lamp with a magnifier, or wearing an Optivisor, is also a good idea.
