If your worried about edge pro diamond stones wearing out then surely the wicked edge ones wont be any better?
The atoma stones must higher quality than the WE diamonds?
The 2" stones work great in the edge pro, I superglued a blank onto the back of mine but a proper holder from CKTG would be better. Tho not sure how they compare price wise to atomas, might not be worth using DMT unless you have some already like I did.
I have experience with the EP apex, EP pro, and now WEPS. Right off of the bat I will say that I have now had my WEPS for about 2 years and am not planning on ever going back to the EP. That being said, back when I got mine the build quality wasn't quite as good as EP (vise bending, slop in the arms) but as CBW said they have fixed the arms now and the vise issue only pops up now and again. However, Clay and his team REALLY go out of their way to take care of you and I have never seen Clay respond to an issue - even when someone posts a public complaint instead of calling in - in any way other than polite and professional and with the utmost in customer service. WEPS even has a forum of it's own where tons of ideas are discussed and you can get help immediately. How cool is that?! =) So I am a fan for life. On to a couple of points...
I have some experience with the Atoma 140's (mounted to WEPS paddles), the DMT course/fine duosharp (freehand plate), and of course the WEPS diamonds. My atomas wore out pretty quickly (using the same pressure) when compared to the WEPS plates - which was surprising since that's ALL atoma does. This has been seen and confirmed by other WEPS users as well that have tried them out. Clay was willing to carry them but when he tested them he felt the same. My DMT's wore bald spots on the edges of the stones, which was not cool; now I can't get into the base of the blade near the choil very well. This was only after a few knives too (and I wasn't using a ton of pressure). So far, I have sharpened around 150 blades on the same set of stones. I am getting a couple of slightly worn spots on my 600's, but other than that I haven't noticed anything. Remember the innovation I was telling you about? Clay is working with some super secret squirrel company and is testing some stones that you basically cannot wear out... they are diamond thru and thru - not just plated. They would be expensive but I believe probably worth the investment if you sharpen a lot. I am hoping to check them out at blade this year (if he brings them
One of the things I really love about the WEPS is that it is not nearly as messy. And this lack of mess means that you are less likely to scratch blades up. Now for my own blades I could care less, but I also sharpen very expensive custom pocket knives and the WEPS is my go to "machine" =D. Even with the tape on the EP I found that the water would get under it and scratch the blades sometimes.
The only and main limiting factor in my opinion is the minimum angle mark... you can get a little lower with the low angle adaptor but it's around 11-12 dps. Still not as low as the EP.
** edit: as stated I will be at blade (saturday only). If you would like to meet up at the WEPS table I know Clay would like to meet you and go over any questions you may have (I would be happy to as well). You could get some hands on possibly as well and see how you like the WEPS.
also just saw where WEPS is having a
father's day sale! only on the field and sport model and accessories though...
