Westinghouse CW/CCW wiring ?
I hope you guys can help,
I have a Westinghouse 1HP 115/230 V single phase,
I want to put a spdt switch in it to reverse rotation, the wires all come out of a cavity in the side and are numbered and connected with wire nuts on the side plate it says to reverse rotation interchange leads 5 & 6 with 7 & 8 ,
there are two capaciters 7 goes to one 8 goes to the other both are connected to 3 and 9 ,
5 & 6 are connected to another wire marked 0 or D ,
should I connect 7&8 to one side of the switch 3&9 to the center and 6&5 to the other side and what do I do with the wire marked 0orD should I wire it in with 6&5 or tape it off and let it hang.
If you are running it on 110V then switch 5 & 8. I am not that firmilar with the 200V process, someone with more electroninc knowldege should pick up on this thread soon! Good luck!
